How to find root cause from GPU STATE DUMP?
plwr
How to find the root cause from GPU STATE DUMP below other than DMA was stuck at 0x3BB00480 address?
AXI BUS ERROR
GPU[0](ChipModel=0x7000 ChipRevision=0x6204):
*** GPU STATE DUMP ***
axi = 0x0000025F
idle = 0x7FFFFFFE
FE not idle
DMA appears to be stuck at this address:
0x3BB00480
dmaLow = 0x00000000
dmaHigh = 0x00000000
dmaState = 0x00000000
command state = 0 (PAR_IDLE_ST)
command DMA state = 0 (CMD_IDLE_ST)
command fetch state = 0 (FET_IDLE_ST)
DMA request state = 0 (REQ_IDLE_ST)
cal state = 0 (CAL_IDLE_ST)
VE request state = 0 (VER_IDLE_ST)
Debug registers:
RA[0] debug registers:
[00] 133F41AF E512EBBC E512EBBC 02107453 031F0000 0A00087F F40F8632 685F80C0
[08] 911D7C00 144CEC2B 2DA9BB60 00000000 00000010 3C2A1F69 A8B4C12F 00000000
[10] 63BAFFBB 23439121 45826400 60980000 12344321 12344321 12344321 12344321
[18] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[20] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[28] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[30] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[38] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[40] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[48] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[50] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[58] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[60] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[68] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[70] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[78] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[80] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[88] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[90] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[98] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[A0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[A8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[B0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[B8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[C0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[C8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[D0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[D8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[E0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[E8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[F0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[F8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
TX[0] debug registers:
[00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
FE[0] debug registers:
[00] 3BB00478 00000000 00000000 00000003 000E014E 00000000 00000001 00000001
[08] 0000000E 06F6FC5F 0067A7A9 00000000 00000000 A7FFFFD8 00000050 BABEF00D
[10] 00000000 359FCC97 B9C86E60 45674567 45674567 45674567 45674567 45674567
[18] 45674567 45674567 00000000 45674567 00000000 45674567 00000051 00000051
[20] 10084ABD 00000001 000000A0 00000000 00000000 AAE6A010 00000001 00000051
[28] 00000040 FE01FE01 FE01FE01 FE01FE01 FE01FE01 FE01FE01 FE01FE01 FE01FE01
[30] 0000065E 00003449 00000000 00000000 00000001 00000051 00000240 00000001
[38] 01C01000 AAE6A070 00000000 0000002F FE02FE02 FE02FE02 FE02FE02 FE02FE02
[40] 00002E10 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[48] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[50] 00000000 AAE6A040 00000000 00000000 00000000 45674567 45674567 45674567
[58] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[60] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[68] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[70] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[78] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[80] 3BB00478 00000000 00000000 00000003 000E014E 00000000 00000001 00000001
[88] 0000000E 06F6FC5F 0067A7A9 00000000 00000000 A7FFFFD8 00000051 BABEF00D
[90] 00000000 359FCC97 C0A422AE 45674567 45674567 45674567 45674567 45674567
[98] 45674567 45674567 00000000 45674567 00000000 45674567 00000051 00000051
[A0] 10084ABD 00000001 000000A0 00000000 00000000 AAE6A010 00000001 00000051
[A8] 00000040 FE01FE01 FE01FE01 FE01FE01 FE01FE01 FE01FE01 FE01FE01 FE01FE01
[B0] 0000065E 00003449 00000000 00000000 00000001 00000051 00000240 00000001
[B8] 01C01000 AAE6A070 00000000 0000002F FE02FE02 FE02FE02 FE02FE02 FE02FE02
[C0] 00002E10 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[C8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[D0] 00000000 AAE6A040 00000000 00000000 00000000 45674567 45674567 45674567
[D8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[E0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[E8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[F0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[F8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
PE[0] debug registers:
[00] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[08] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[10] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[18] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[20] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[28] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[30] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[38] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[40] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[48] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[50] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[58] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[60] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[68] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[70] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[78] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[80] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[88] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[90] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[98] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[A0] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[A8] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[B0] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[B8] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[C0] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[C8] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[D0] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[D8] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[E0] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[E8] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[F0] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
[F8] 00000001 00000001 00000001 00000001 00000001 00000001 00000001 00000001
PE[1] debug registers:
[80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
DE[0] debug registers:
SH[0] debug registers:
[00] B2FFEAA3 551FC000 0008F004 000008AA 458F920F 0027E14F 0027E14E 72F0B554
[08] 133F41AF 27372F72 0627AC8A 00000000 00000000 00000000 00000000 53A8801D
[10] E435F909 E81D4522 014728DE 10C7F03A A882BB1F FEC284DC 03C43773 00000000
[18] 00000000 0000350C 953300A1 CAFEF00D CAFEF00D CAFEF00D F0000000 DD000103
[20] 00000003 00000000 0000002F 00000200 01F04984 6697F97F 15140201 13001200
[28] 08B10000 00000000 00000000 FFF007FF F00EC01F 00000000 00000000 40000001
[30] FFFFFFFF BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[38] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[40] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[48] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[50] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[58] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[60] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[68] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[70] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[78] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[80] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[88] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[90] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[98] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[A0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[A8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[B0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[B8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[C0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[C8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[D0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[D8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[E0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[E8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[F0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[F8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D DEADBEEF
PA[0] debug registers:
SE[0] debug registers:
[00] 0A8550A8 01555555 15555555 05555540 05555555 00002501 00400000 00000000
[10] 00000000 00000000 00000000 00000000 00000000 5E5E5E5E 5E5E5E5E 5E5E5E5E
[18] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[20] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[28] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[30] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[38] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[40] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[48] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[50] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[58] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[60] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[68] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[70] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[78] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[80] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[88] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[90] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[98] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[A0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[A8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[B0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[B8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[C0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[C8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[D0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[D8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[E0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[E8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[F0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[F8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
MC[0] debug registers:
[00] B105C8B0 00000000 00000000 00000000 00000000 00000000 B105C8B0 00000000
[08] 00000000 00000000 00000000 00000000 B105C8B0 00000000 00000000 00000000
[18] 00000000 00000000 00000000 00000000 00000000 CCCCCC6A 00000000 00000000
[20] 00001100 00000000 0D2EB9D0 12345678 12345678 12345678 12345678 12345678
[28] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[30] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[38] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[40] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[50] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[60] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[70] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[80] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[90] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[A0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[B0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[C0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[D0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[E0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[F0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
MC[1] debug registers:
HI[0] debug registers:
[00] 00000000 00000000 00000000 F000B565 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[08] AD21A0CA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[10] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[18] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[20] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[28] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[30] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[38] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[40] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[48] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[50] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[58] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[60] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[68] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[70] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[78] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[80] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[88] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[90] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[98] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[A0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[A8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[B0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[B8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[C0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[C8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[D0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[D8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[E0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[E8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[F0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[F8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
TPG[1] debug registers:
TFB[1] debug registers:
USC[1] debug registers:
[C0] 11500000 DC000303 00000000 00000000 00000000 00000000 00000000 00000000
[C8] 11500000 DC000303 00000000 00000000 00000000 00000000 00000000 00000000
[D0] 000004D0 00000000 00001340 00000000 000004D0 00000000 00001340 00000000
[D8] 000004D0 00000000 00001340 00000000 000004D0 00000000 00001340 00000000
L2[0] debug registers:
BLT[0] debug registers:
Other Registers[0]:
[0x0040] 0x00000000
[0x0044] 0x00000000
[0x004C] 0x00000000
[0x0050] 0x00000000
[0x0054] 0x00000000
[0x0058] 0x00000000
[0x005C] 0x00000000
[0x0060] 0x00000000
[0x043C] 0x00000000
[0x0440] 0x00000000
[0x0444] 0x00001D00
[0x0414] 0x3C000000
[0x0100] 0x00140021
MMU status from MC[0]:
*** MMU ERROR DUMP ***
MMU status = 0x00000000
Link stack:
[0x00] 0xA7FFFFD8 [0x01] 0xA7FFFFD8 [0x02] 0xA7FFFFD8 [0x03] 0xA7FFFFD8
[0x04] 0xA7FFFFD8 [0x05] 0xA7FFFFD8 [0x06] 0xA7FFFFD8 [0x07] 0xA7FFFFD8
[0x08] 0xA7FFFFD8 [0x09] 0xA7FFFFD8 [0x0A] 0xA7FFFFD8 [0x0B] 0xA7FFFFD8
[0x0C] 0xA7FFFFD8 [0x0D] 0xA7FFFFD8 [0x0E] 0xA775FF42 [0x0F] 0xA7FFFFD8
PRE_STACK:
CMD_STACK:
LINK_STACK:
00000051 00000051 00000051 00000051 00000051 00000051 00000051 00000051
***** SW COUNTERS *****
Execute Count = 0x0004A808
Execute Addr = 0x3FFFFEC0
End Addr = 0x3FFFFEB0
Tags (2)
Wobaffet
Senior Contributor I
Any Updates related to this matter?
