Datasheet of G2D GC520L
1,413 次查看
gaelp
I am currently working on iMX8 MPlus, and I would like to have the datasheet of the GPU 2D - GC520L. I can't find the actual datasheet anywhere.
The first need of this datasheet is to know the maximum resolution possible for a color conversion.
Also, I would like to know if this GC520L is able to do multiple color conversion at the same time.
Thanks.
标记 (2)
1,401 次查看
gaelp
Thank you for your answer.
I have seen this already but it is just an overview of the GC520L and it is a bit succinct.
Anyway, this webpage says that the Resolution support is 1080p, what do you think about that ?
1,403 次查看
Bio_TICFSL
You can see all the ip information about GC250L form verisilicon https://www.chipestimate.com/VeriSilicon/GC520L/datasheet/ip/41812
