IMX6 eglGetDisplay used too much memory
1,207件の閲覧回数
JoRadio
When I initialize EGL display using the FB API of IMX6, the eglGetDisplay function will occupy 140MB of memory after being called. Is this normal? Why does each OpenGL program occupy so much memory?
2 返答(返信)
1,190件の閲覧回数
Zhiming_Liu
It's not just FB that is allocated, Tthe following buffers are also allocated:
  • GPU Command Buffers
  • Shader Compilation Buffer
  • Texture/Buffer management pool
  • DRM/FB device cache
Zhiming
1,173件の閲覧回数
JoRadio
I have used IMX8 products. When initializing OpenGL, this product doesn't need to allocate so much memory, so I think this is a GPU driver defect of IMX6. If each process that uses OpenGL needs to allocate so much memory, the total number of processes will be limited.
