eIQ on phyBOARD with i.MX 8M Mini
ML1992
I have a question on how to start with eIQ on the phyBOARD - Polis with phyCORE-i.MX 8M Mini.
My plan is to take TF-Lite models (I already have the .tflite files) and run the inference on the i.MX 8M Mini to check the inference time.
Which Software should I install and how can I run inference for my models?
(I'm working with a virtual machine with Ubuntu, BSP-Yocto-FSL-i.MX8MM-PD20.1.0. The Version on the board is BSP-Yocto-FSL-i.MX8MM-PD20.1.0)
Thank you
