eIQ Sample Apps - Face Recognition using TF Lite
This Lab 4 explains how to get started with TensorFlow Lite application demo on i.MX8 board using Inference Engines for eIQ Software.
Get the source code available on code aurora:
TensorFlow Lite MobileFaceNets MIPI/USB Camera
Face Detection Using OpenCV
This application demo uses Haar Feature-based Cascade Classifiers for real time face detection. The pre-trained Haar Feature-based Cascade Classifiers for face, named as XML, is already contained in OpenCV. The XML file for face is stored in the opencv/data/haarcascades/ folder as well as code aurora. Read Face Detection using Haar Cascades for more details.
TensorFlow Lite implementation for MobileFaceNets
The MobileFaceNets is re-trained on a host PC with a smaller batch size and input size to get higher performance. The trained model is loaded as a source file in this demo.
Setting Up the Board
Step 1 - Download the demo from eIQ Sample Apps and put it in /opt/tflite folder. Then enter the src folder:
root@imx8mmevk:~# cd /opt/tflite/examples-tflite/face_recognition/src/
root@imx8mmevk:/opt/tflite/examples-tflite/face_recognition/src#
This folder should include these files:
├── face_detect_helpers.cpp
├── face_detect_helpers.h
├── face_detect_helpers_impl.h
├── face_recognition.cpp
├── face_recognition.h
├── haarcascade_frontalface_alt.xml
├── Makefile
├── mfn.h
├── profiling.h
└── ThreadPool.h
Step 2 - Compile the source code on the board:
root@imx8mmevk:/opt/tflite/examples-tflite/face_recognition/src# make
Step 3 - Run the demo:
root@imx8mmevk:/opt/tflite/examples-tflite/face_recognition/src# ./FaceRecognition -c 0 -h 0.85
NOTE: -c is used to specify the camera index. '0' means the MIPI/USB camera is mounted on /dev/video0. -h is a threshold for the prediction score.
Step 4 - Add a new person to the face data set.
When the demo is running, it will detect one biggest face at real time. Once the face is detected, you can click keyboards on the right of GUI to input the new person's name. Then, click 'Add new person' to add the face to data set.
In brief,
1. Detect face.
2. Input new person's name.
3. Click 'Add new person'.
NOTE: Once new faces are added, it will create a folder named 'data' in current directory. If you want to remove the new face from the data set, just delete it in 'data'.
评论
HI Diego,
This still refer to an old Tensorflow version, from r1.13, Tensorflow Lite has been migrated out of Tensorflow Contrib
face_recognition.cpp:52:10: fatal error: tensorflow/contrib/lite/kernels/register.h: No such file or directory
   52 | #include "tensorflow/contrib/lite/kernels/register.h"
compilation terminated.
In file included from face_detect_helpers.h:23,
                 from face_detect_helpers.cpp:13:
face_detect_helpers_impl.h:30:10: fatal error: tensorflow/contrib/lite/builtin_op_data.h: No such file or directory
   30 | #include "tensorflow/contrib/lite/builtin_op_data.h"
best regards,
Rod
Hi Rod,
In new TF-Lite version, these headers can be found at tensorflow/lite.
You can replace path of these headers in face_recognition.cpp and face_detect_helpers_impl.h by the following:
#include "tensorflow/lite/kernels/register.h"#include "tensorflow/lite/model.h"#include "tensorflow/lite/optional_debug_tools.h"#include "tensorflow/lite/string_util.h"
#include "tensorflow/lite/builtin_op_data.h"
#include "tensorflow/lite/interpreter.h"
Then link the corresponding tensorflow-lite.a to build the app.
BR,
Devin
I am trying to run this face recognition app with tf lite building on the imx8mqevk board, facing this error .. what is the solution
imx8mqevk:/opt/face_recognition/src# make
g++ -o FaceRecognition -I /usr/include/tensorflow/contrib/lite/tools/make/downloads/flatbuffers/include/ face_recognition.cpp face_detect_helpers.cpp -ltensorflow-lite -lpthread -ldl -g -lopencv_objdetect -lopencv_highgui -lopencv_imgproc -lopencv_core -lopencv_videoio -lopencv_imgcodecs
In file included from face_recognition.cpp:59:
face_detect_helpers.h:18:10: fatal error: opencv2/objdetect.hpp: No such file or directory
#include "opencv2/objdetect.hpp"
In file included from face_detect_helpers.cpp:13:
Hi Manivannan,
OpenCV is required for this App. The errors are caused by no OpenCV header files in your rootfs. Can you double check if OpenCV was installed in your SDcard Image?
Hi Devin,
Thanks for the reply , i have added the following in local conf , its  there in the image, what could be missing.
#Configure the OpenCV package:
IMAGE_INSTALL_append = "opencv python-opencv"
PACKAGECONFIG_remove_pn-opencv_mx8 = "python3"
PACKAGECONFIG_append_pn-opencv_mx8 = " dnn jasper openmp test neon python2 qt5 gtk "
#Add CMake for SDK’s cross-compile:
TOOLCHAIN_HOST_TASK_append += " nativesdk-cmake nativesdk-make"
IMAGE_INSTALL_append = " \
flatbuffers \
arm-compute-library \
tensorflow-lite \
armnn \
armnn-onnx \
PREFERRED_VERSION_opencv = "4.0.1%"
PREFERRED_VERSION_tensorflow-lite = "1.12.0%"
Hi Manivannan,
From your local conf, the OpenCV should be included in the image. You can use Linux command "find" to get the OpenCV header files path on your target, then add the path to the include path and compile the app again.
For example,
find /usr/ -name opencv2
Then,
export CPLUS_INCLUDE_PATH=/usr/<your opencv2 path>
make
Alternatively, you can also build all of the eiq sample apps in Yocto project, following Deploying the eIQ Sample Apps to an i.MX8 board.
The link to "TensorFlow Lite MobileFaceNets MIPI/USB Camera" at the top of the page is not accessible now that NXP moved from Code Auorora to github. I can't find the C++ facial recognition examples in github, only the python ones.
May I please ask where are the C++ examples?
%3CLINGO-SUB%20id%3D%22lingo-sub-1122442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20%E5%AE%9E%E9%AA%8C%E5%AE%A4%204%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E8%A7%A3%E9%87%8A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fsoftware-center%2Feiq-ml-development-environment%3AEIQ%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20eIQ%3C%2FA%3E%20%E8%BD%AF%E4%BB%B6%E6%8E%A8%E7%90%86%E5%BC%95%E6%93%8E%20%E5%9C%A8%20i.MX8%20%E6%9D%BF%E4%B8%8A%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2F1-example%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20TensorFlow%20Lite%3C%2FA%3E%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343785%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3EeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E6%A6%82%E8%BF%B0%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343741%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3EeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%20-%20%E4%BB%8B%E7%BB%8D%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%8E%B7%E5%8F%96%E5%9C%A8%20Code%20Aurora%20%E4%B8%8A%E5%8F%AF%E7%94%A8%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2Fface_recognition%2Fsrc%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETensorFlow%20Lite%20MobileFaceNets%20MIPI%2FUSB%20%E6%91%84%E5%83%8F%E5%A4%B4%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2022px%3B%22%3E%E4%BD%BF%E7%94%A8%20OpenCV%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E6%A3%80%E6%B5%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E6%AD%A4%E5%BA%94%E7%94%A8%E6%BC%94%E7%A4%BA%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20Haar%20%E7%89%B9%E5%BE%81%E7%9A%84%E7%BA%A7%E8%81%94%E5%88%86%E7%B1%BB%E5%99%A8%E8%BF%9B%E8%A1%8C%E5%AE%9E%E6%97%B6%E4%BA%BA%E8%84%B8%E6%A3%80%E6%B5%8B%E3%80%82OpenCV%20%E4%B8%AD%E5%B7%B2%E5%8C%85%E5%90%AB%E9%A2%84%E5%85%88%E8%AE%AD%E7%BB%83%E5%A5%BD%E7%9A%84%E5%9F%BA%E4%BA%8E%20Haar%20%E7%89%B9%E5%BE%81%E7%9A%84%E4%BA%BA%E8%84%B8%E7%BA%A7%E8%81%94%E5%88%86%E7%B1%BB%E5%99%A8%EF%BC%88%E4%BB%A5%20XML%20%E6%A0%BC%E5%BC%8F%E5%91%BD%E5%90%8D%EF%BC%89%E3%80%82%E4%BA%BA%E8%84%B8%20XML%20%E6%96%87%E4%BB%B6%E4%B8%8E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2F1-example%2Fsrc%2Fhaarcascade_frontalface_alt.xml%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%BB%A3%E7%A0%81%20aurora%3C%2FA%3E%E4%B8%80%E8%B5%B7%E5%AD%98%E5%82%A8%E5%9C%A8%20opencv%2Fdata%2Fhaarcascades%2F%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%E9%98%85%E8%AF%BB%3CA%20href%3D%22https%3A%2F%2Fdocs.opencv.org%2F4.0.1%2Fd7%2Fd8b%2Ftutorial_py_face_detection.html%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%BD%BF%E7%94%A8%20Haar%20Cascades%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E6%A3%80%E6%B5%8B%3C%2FA%3E%E4%BB%A5%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ETensorFlow%20Lite%20%E7%9A%84%20MobileFaceNets%20%E5%AE%9E%E7%8E%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Farxiv.org%2Fabs%2F1804.07573%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMobileFaceNets%3C%2FA%3E%E5%9C%A8%E4%B8%BB%E6%9C%BA%20PC%20%E4%B8%8A%E4%BB%A5%E8%BE%83%E5%B0%8F%E7%9A%84%E6%89%B9%E9%87%8F%E5%A4%A7%E5%B0%8F%E5%92%8C%E8%BE%93%E5%85%A5%E5%A4%A7%E5%B0%8F%E9%87%8D%E6%96%B0%E8%AE%AD%E7%BB%83%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%9B%B4%E9%AB%98%E7%9A%84%E6%80%A7%E8%83%BD%E3%80%82%E5%9C%A8%E6%9C%AC%E6%BC%94%E7%A4%BA%E4%B8%AD%EF%BC%8C%E8%AE%AD%E7%BB%83%E5%A5%BD%E7%9A%84%E6%A8%A1%E5%9E%8B%E4%BD%9C%E4%B8%BA%E6%BA%90%E6%96%87%E4%BB%B6%E5%8A%A0%E8%BD%BD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-size%3A%2022px%3B%22%3E%E8%AE%BE%E7%BD%AE%E7%94%B5%E8%B7%AF%E6%9D%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%201%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-%20%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EeIQ%20Sample%20Apps%3C%2FA%3E%E4%B8%8B%E8%BD%BD%E6%BC%94%E7%A4%BA%E5%B9%B6%E5%B0%86%E5%85%B6%E6%94%BE%E5%9C%A8%20%2Fopt%2Ftflite%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%E7%84%B6%E5%90%8E%E8%BF%9B%E5%85%A5src%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%3CP%3Eroot%40imx8mmevk%3A~%23%20cd%20%2Fopt%2Ftflite%2Fexamples-tflite%2Fface_recognition%2Fsrc%2F%3C%2FP%3E%3CP%3Eroot%40%20%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3Eimx8mmevk%3C%2FSPAN%3E%20%3A%2Fopt%2Ftflite%2Fexamples-tflite%2Fface_recognition%2Fsrc%23%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%AF%A5%E6%96%87%E4%BB%B6%E5%A4%B9%E5%BA%94%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%3CP%3E%E3%80%82%3CBR%20%2F%3E%20%E2%94%82%20%E2%94%82%20%E4%BA%BA%E8%84%B8%E6%A3%80%E6%B5%8B%E5%8A%A9%E6%89%8B.cpp%3CBR%20%2F%3E%20%E2%94%82%20...%3CBR%20%2F%3E%20%E2%94%82%20...%3CBR%20%2F%3E%20%E2%94%82%20%E2%94%82%20%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB.cpp%3CBR%20%2F%3E%E2%94%82%20%E2%94%82%20%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB.h%3CBR%20%2F%3E%E2%95%90%E2%94%80%E2%94%80%20haarcascade_frontalface_alt.xml%3CBR%20%2F%3E%E2%94%82%20%E2%94%82%20Makefile%3CBR%20%2F%3E%20%E2%94%82%20%E2%94%82%20%E2%94%82%20%E2%94%82%20%E2%94%82%3CBR%20%2F%3E%20%E2%94%82%20...%3CBR%20%2F%3E%E2%94%94%E2%94%80%E2%94%80%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3E%E7%BA%BF%E7%A8%8B%E6%B1%A0.h%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E%E7%AC%AC%202%20%E6%AD%A5%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-%20%E5%9C%A8%E6%9D%BF%E4%B8%8A%E7%BC%96%E8%AF%91%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%3CP%3Eroot%40%20%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3Eimx8mmevk%3C%2FSPAN%3E%20%3A%2Fopt%2Ftflite%2Fexamples-tflite%2Fface_recognition%2Fsrc%23%20make%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A43%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-%20%E8%BF%90%E8%A1%8C%E6%BC%94%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%3CP%3Eroot%40%20%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3Eimx8mmevk%3C%2FSPAN%3E%20%3A%2Fopt%2Ftflite%2Fexamples-tflite%2Fface_recognition%2Fsrc%23.%2FFaceRecognition-c%200%20-h%200.85%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%3C%2FSTRONG%3E%EF%BC%9A-c%20%E7%94%A8%E4%BA%8E%E6%8C%87%E5%AE%9A%E7%9B%B8%E6%9C%BA%E7%B4%A2%E5%BC%95%E3%80%82'0'%20%E8%A1%A8%E7%A4%BA%20MIPI%2FUSB%20%E6%91%84%E5%83%8F%E5%A4%B4%E5%AE%89%E8%A3%85%E5%9C%A8%20%2Fdev%2Fvideo0%20%E4%B8%8A%E3%80%82-h%20%E6%98%AF%E9%A2%84%E6%B5%8B%E5%88%86%E6%95%B0%E7%9A%84%E9%98%88%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A44%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-%20%E5%B0%86%E6%96%B0%E4%BA%BA%E6%B7%BB%E5%8A%A0%E5%88%B0%E4%BA%BA%E8%84%B8%E6%95%B0%E6%8D%AE%E9%9B%86%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%BC%94%E7%A4%BA%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E5%AE%83%E5%B0%86%E6%A3%80%E6%B5%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E4%B8%80%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%AE%9E%E6%97%B6%E6%9C%80%E5%A4%A7%E7%9A%84%E8%84%B8%E3%80%82%E4%B8%80%E6%97%A6%E6%A3%80%E6%B5%8B%E5%88%B0%E8%84%B8%E9%83%A8%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8D%95%E5%87%BB%20GUI%20%E5%8F%B3%E4%BE%A7%E7%9A%84%E9%94%AE%E7%9B%98%E6%9D%A5%E8%BE%93%E5%85%A5%E6%96%B0%E4%BA%BA%E7%9A%84%E5%A7%93%E5%90%8D%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E5%8D%95%E5%87%BB%E2%80%9C%E6%B7%BB%E5%8A%A0%E6%96%B0%E4%BA%BA%E2%80%9D%E5%B0%86%E4%BA%BA%E8%84%B8%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%95%B0%E6%8D%AE%E9%9B%86%E3%80%82%3C%2FP%3E%3CP%3E%E7%AE%80%E8%80%8C%E8%A8%80%E4%B9%8B%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%3CP%3E1.%E6%A3%80%E6%B5%8B%E4%BA%BA%E8%84%B8%E3%80%82%3C%2FP%3E%3CP%3E2.%E8%BE%93%E5%85%A5%E6%96%B0%E4%BA%BA%E7%9A%84%E5%A7%93%E5%90%8D%E3%80%82%3C%2FP%3E%3CP%3E3.%20%E7%82%B9%E5%87%BB%E2%80%9C%E6%B7%BB%E5%8A%A0%E6%96%B0%E4%BA%BA%E2%80%9D%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%3C%2FSTRONG%3E%EF%BC%9A%E4%B8%80%E6%97%A6%E6%B7%BB%E5%8A%A0%E6%96%B0%E9%9D%A2%E5%AD%94%EF%BC%8C%E5%AE%83%E5%B0%86%E5%9C%A8%E5%BD%93%E5%89%8D%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%E2%80%9C%E6%95%B0%E6%8D%AE%E2%80%9D%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E4%BB%8E%E6%95%B0%E6%8D%AE%E9%9B%86%E4%B8%AD%E5%88%A0%E9%99%A4%E6%96%B0%E9%9D%A2%E5%AD%94%EF%BC%8C%E5%8F%AA%E9%9C%80%E5%9C%A8%E2%80%9C%E6%95%B0%E6%8D%AE%E2%80%9D%E4%B8%AD%E5%88%A0%E9%99%A4%E5%AE%83%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1917034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1917034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20NXP%20%E4%BB%8E%20Code%20Auorora%20%E7%A7%BB%E8%87%B3%20github%EF%BC%8C%E9%A1%B5%E9%9D%A2%E9%A1%B6%E9%83%A8%E7%9A%84%E2%80%9C%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2Fface_recognition%2Fsrc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETensorFlow%20Lite%20MobileFaceNets%20MIPI%2FUSB%20Camera%3C%2FA%3E%20%E2%80%9D%E9%93%BE%E6%8E%A5%E7%8E%B0%E5%B7%B2%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E3%80%82%E6%88%91%E5%9C%A8%20github%20%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%20C%2B%2B%20%E9%9D%A2%E9%83%A8%E8%AF%86%E5%88%AB%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%8F%AA%E6%9C%89%20python%20%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%20C%2B%2B%20%E7%A4%BA%E4%BE%8B%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CManivannan%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BB%8E%E6%82%A8%E7%9A%84%E6%9C%AC%E5%9C%B0conf%E6%9D%A5%E7%9C%8B%EF%BC%8COpenCV%E5%BA%94%E8%AF%A5%E5%8C%85%E5%90%AB%E5%9C%A8%E5%9B%BE%E5%83%8F%E4%B8%AD%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20Linux%20%E5%91%BD%E4%BB%A4%E2%80%9Cfind%E2%80%9D%E8%8E%B7%E5%8F%96%E7%9B%AE%E6%A0%87%E4%B8%8A%E7%9A%84%20OpenCV%20%E5%A4%B4%E6%96%87%E4%BB%B6%E8%B7%AF%E5%BE%84%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E8%AF%A5%E8%B7%AF%E5%BE%84%E6%B7%BB%E5%8A%A0%E5%88%B0%E5%8C%85%E5%90%AB%E8%B7%AF%E5%BE%84%E5%B9%B6%E5%86%8D%E6%AC%A1%E7%BC%96%E8%AF%91%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%E6%9F%A5%E6%89%BE%2Fusr%2F-name%20opencv2%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eexport%20CPLUS_INCLUDE_PATH%3D%2Fusr%2F%3CYOUR%20opencv2%3D%22%22%20path%3D%22%22%3E%3C%2FYOUR%3E%3C%2FP%3E%3CP%3Emake%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%96%E8%80%85%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345134%22%20target%3D%22_blank%22%3E%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%E7%9A%84%3C%2FA%3E%E6%AD%A5%E9%AA%A4%EF%BC%8C%E5%9C%A8%20Yocto%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%9E%84%E5%BB%BA%E6%89%80%E6%9C%89%20eiq%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CDevin%EF%BC%8C%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E6%9C%AC%E5%9C%B0%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%8C%E5%AE%83%E5%9C%A8%E5%9B%BE%E5%83%8F%E4%B8%AD%EF%BC%8C%E5%8F%AF%E8%83%BD%E7%BC%BA%E5%B0%91%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%E9%85%8D%E7%BD%AEOpenCV%E5%8C%85%EF%BC%9A%3CBR%20%2F%3E%20IMAGE_INSTALL_append%20%3D%E2%80%9Copencv%20python-opencv%E2%80%9D%3C%2FP%3E%3CP%3EPACKAGECONFIG_remove_pn-opencv_mx8%20%3D%E2%80%9Cpython3%E2%80%9D%3CBR%20%2F%3E%20PACKAGECONFIG_append_pn-opencv_mx8%20%3D%20%E2%80%9Cdnn%20jasper%20openmp%20%E6%B5%8B%E8%AF%95%20neon%20python2%20qt5%20gtk%E2%80%9D%3C%2FP%3E%3CP%3E%23%E6%B7%BB%E5%8A%A0CMake%E7%94%A8%E4%BA%8ESDK%E7%9A%84%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%EF%BC%9A%3C%2FP%3E%3CP%3ETOOLCHAIN_HOST_TASK_append%20%2B%3D%20%22%20nativesdk-cmake%20nativesdk-make%22%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3CBR%20%2F%3E%E5%B9%B3%E9%9D%A2%E7%BC%93%E5%86%B2%E5%8C%BA%20%5C%3CBR%20%2F%3E%20arm-%E8%AE%A1%E7%AE%97%E5%BA%93%20%5C%3CBR%20%2F%3E%20tensorflow-lite%20%5C%3CBR%20%2F%3E%20armnn%20%5C%3CBR%20%2F%3E%20armnn-onnx%20%5C%3CBR%20%2F%3E%20%E2%80%9C%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC%20opencv%20%3D%20%224.0.1%25%22%3CBR%20%2F%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_tensorflow-lite%20%3D%E2%80%9C1.12.0%25%E2%80%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CManivannan%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%9C%80%E8%A6%81%20OpenCV%E3%80%82%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E4%BA%8E%E6%82%A8%E7%9A%84%20rootfs%20%E4%B8%AD%E6%B2%A1%E6%9C%89%20OpenCV%20%E5%A4%B4%E6%96%87%E4%BB%B6%E5%BC%95%E8%B5%B7%E7%9A%84%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E5%86%8D%E6%AC%A1%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%20SD%20%E5%8D%A1%E6%98%A0%E5%83%8F%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AE%89%E8%A3%85%E4%BA%86%20OpenCV%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20imx8mqevk%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E7%9A%84%20tf%20lite%20%E6%9E%84%E5%BB%BA%E8%BF%90%E8%A1%8C%E6%AD%A4%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E9%81%87%E5%88%B0%E6%AD%A4%E9%94%99%E8%AF%AF...%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E4%BB%80%E4%B9%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx8mqevk%3A%2Fopt%2Fface_recognition%2Fsrc%23%20make%3CBR%20%2F%3E%20g%2B%2B%20-o%20FaceRecognition%20-I%20%2Fusr%2Finclude%2Ftensorflow%2Fcontrib%2Flite%2Ftools%2Fmake%2Fdownloads%2Fflatbuffers%2Finclude%2Fface_recognition.cpp%20face_detect_helpers.cpp%20-ltensorflow-lite%20-lpthread%20-ldl%20-g%20-lopencv_objdetect%20-lopencv_highgui%20-lopencv_imgproc%20-lopencv_core%20-lopencv_videoio%20-lopencv_imgcodecs%3CBR%20%2F%3E%E5%9C%A8%20face_recognition.cpp%3A59%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20face_detect_helpers.h%3A18%3A10%3A%20%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Aopencv2%2Fobjdetect.hpp%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%23include%20%22opencv2%2Fobjdetect.hpp%22%3CBR%20%2F%3E%20%5E~~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%20face_detect_helpers.cpp%3A13%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20face_detect_helpers.h%3A18%3A10%3A%20%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Aopencv2%2Fobjdetect.hpp%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%23include%20%22opencv2%2Fobjdetect.hpp%22%3CBR%20%2F%3E%20%5E~~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Rod%2C%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%96%B0%E7%9A%84%20TF-Lite%20%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E8%BF%99%E4%BA%9B%E6%A0%87%E5%A4%B4%E5%8F%AF%E4%BB%A5%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Ftensorflow%2Ftensorflow%2Ftree%2Fv2.0.0%2Ftensorflow%2Flite%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Etensorflow%2Flite%3C%2FA%3E%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E6%9B%BF%E6%8D%A2%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2Fface_recognition%2Fsrc%2Fface_recognition.cpp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eface_recognition.cpp%3C%2FA%3E%E5%92%8C%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2Fface_recognition%2Fsrc%2Fface_detect_helpers_impl.h%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eface_detect_helpers_impl.h%3C%2FA%3E%E4%B8%AD%E8%BF%99%E4%BA%9B%E6%A0%87%E9%A2%98%E7%9A%84%E8%B7%AF%E5%BE%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2Fface_recognition%2Fsrc%2Fface_recognition.cpp%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20underline%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB.cpp%3C%2FA%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CPRE%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%E2%80%9Ctensorflow%2Flite%2Fkernels%2Fregister.h%E2%80%9D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%EF%BC%83%E5%8C%85%E6%8B%AC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%E2%80%9Ctensorflow%2Flite%2Fmodel.h%E2%80%9D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%EF%BC%83%E5%8C%85%E6%8B%AC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%E2%80%9Ctensorflow%2Flite%2Foptional_debug_tools.h%E2%80%9D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%EF%BC%83%E5%8C%85%E6%8B%AC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%E2%80%9Ctensorflow%2Flite%2Fstring_util.h%E2%80%9D%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2Fexamples-tflite%2Fface_recognition%2Fsrc%2Fface_detect_helpers_impl.h%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%BA%BA%E8%84%B8%E6%A3%80%E6%B5%8B%E5%8A%A9%E6%89%8B_impl.h%3C%2FA%3E%3C%2FP%3E%3CPRE%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013.3333px%3B%22%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%22tensorflow%2Flite%2Fbuiltin_op_data.h%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%22tensorflow%2Flite%2Finterpreter.h%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%E2%80%9Ctensorflow%2Flite%2Fkernels%2Fregister.h%E2%80%9D%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-weight%3A%20bold%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%22%3E%22tensorflow%2Flite%2Fstring_util.h%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%E7%84%B6%E5%90%8E%E9%93%BE%E6%8E%A5%E7%9B%B8%E5%BA%94%E7%9A%84tensorflow-lite.a%E6%9D%A5%E6%9E%84%E5%BB%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EBR%EF%BC%8C%3CBR%20%2F%3E%E5%BE%B7%E6%96%87%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20%E4%BD%BF%E7%94%A8%20TF%20Lite%20%E8%BF%9B%E8%A1%8C%E4%BA%BA%E8%84%B8%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Diego%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BB%8D%E7%84%B6%E6%8C%87%E7%9A%84%E6%98%AF%E6%97%A7%E7%9A%84%20Tensorflow%20%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BB%8E%20r1.13%20%E5%BC%80%E5%A7%8B%EF%BC%8CTensorflow%20Lite%20%E5%B7%B2%E7%BB%8F%E4%BB%8E%20Tensorflow%20Contrib%20%E4%B8%AD%E8%BF%81%E7%A7%BB%E5%87%BA%E6%9D%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eface_recognition.cpp%3A52%3A10%3A%20%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Atensorflow%2Fcontrib%2Flite%2Fkernels%2Fregister.h%3A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E52%20%7C%20%23include%20%E2%80%9Ctensorflow%2Fcontrib%2Flite%2Fkernels%2Fregister.h%E2%80%9D%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%20face_detect_helpers.h%3A23%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%20face_detect_helpers.cpp%3A13%EF%BC%9A%3CBR%20%2F%3E%20face_detect_helpers_impl.h%3A30%3A10%EF%BC%9A%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Atensorflow%2Fcontrib%2Flite%2Fbuiltin_op_data.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E30%20%7C%20%23include%20%E2%80%9Ctensorflow%2Fcontrib%2Flite%2Fbuiltin_op_data.h%E2%80%9D%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERod%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎06-21-2019 09:45 AM
更新人:
