PRELU operation error
2,469 次查看
dbinaghi
I'm using a iMX8M Plus with a quantised tensorflow lite model (uint8).
The tflite
runtime version is the 2.3.1.
My model contains some PRELU operations that according to the guide is a supported operation.
A warning is reported:
WARNING: Operator PRELU (v1) refused by NNAPI delegate: Input should be Float or UINT8
I think this is due to the fact that the tensor during processing becomes an int8 but it should be supported. This warning does not happen if I use a RELU activation function instead of PRELU.
The quantised model is attached.
Could you help me?
Thanks!
0 回复数
