Is opencv ported on imxrt crossover processors?
4,257件の閲覧回数
gururaghavendra
i want to run opencv operations on imxrt crossover processors.
if it is not supported are there any other libraries which does operations similar to opencv?
Guru V
3 返答(返信)
4,031件の閲覧回数
anthony_huereca
Hi Guru,
  At this time we do not have OpenCV enablement for i.MX RT crossover processors. This is an area we are exploring though, and any future announcements for i.MX RT support can be found on the eIQ website. eIQ™ OpenCV Neural Network and ML Algorithm Support | NXP. What kind of ML application were you looking to do?
  There is OpenCV enablement for our i.MX application processors in case you're interested in that: eIQ Sample Apps - Object Recognition using OpenCV DNN
Anthony
4,031件の閲覧回数
gururaghavendra
Hi Anthony,
Thanks for your response. i am having other question.
Is there any document to give details about flashing and booting the imxrt060-evk board from SD Card using mcuexpresso IDE?
There is a reference doc for the same using MFGTool but not with mcuexpresso IDE.
Guru V
4,031件の閲覧回数
anthony_huereca
Hi Guru,
  This app note should help explain the steps. It does require using the MFGTool for booting from SD card: https://www.nxp.com/docs/en/application-note/AN12107.pdf
  For any future RT device questions that are not eIQ related, I would recommend posting in the i.MX RT community which can provide more focused support: i.MX RT
Anthony
