Importing images to eiq portal
2,768 次查看
Olatz
I tried importing a large folder of images using the script Structured Folders Importer.ipynb and following the Data Import Lab instructions. I got an error that said:
RuntimeError                              Traceback (most recent call last)
~\AppData\Local\Temp/ipykernel_1568/4095886512.py in <module>
     32             images.append(f.read())
     33     if label is not None:
---> 34         for image_id in project.add_images(images, grouping
     35             project.add_annotation(image_id, label)
C:\nxp\eIQ_Toolkit_v1.0.5\python\Lib\site-packages\deepview\datastore\project.pyc in add_images(self, images, grouping)
RuntimeError: context canceled
I also tried the same process with a folder containing a small group of images and it worked perfectly, so I think the problem comes from having too many images (around 1500) because I've had similar issues importing unlabeled large datasets before. Is there a way to solve this error and import large labeled datasets?
Thank you in advance.
2,721 次查看
david_piskula
Hello @Olatz,
it appears you are using the eIQ Toolkit version v1.0.5. Could you please update to the latest version and let me know if the issue persists?
https://www.nxp.com/design/software/development-software/eiq-ml-development-environment/eiq-toolkit-...
David
2,722 次查看
david_piskula
Hello @Olatz,
David
2,709 次查看
Olatz
Thank you very much! I tried upded the portal and it works now.
Olatz
