How to use tvm
How to use tvm
2,472 次查看
weilly_li
Hi, Gus
    Recently,  I'm trying tvm framework has some confuse issue.
     I can't find where is example source( /tests/python/contrib/test_vsi_npu)  from "i.MX Machine Learning User's Guide.pdf"
     And, I  can't find  test_tflite_models.py in yocoto downloaded source code (/bld-xwayland/tmp/work/cortexa53-crypto-poky-linux/tvm/0.7.0-r0/git) .
      Has Someone Same Issue? Can I Discuss With You?  I'll be very grateful to you.
Weilly
0 回复数
