Can not get correct inference result
已解决
跳至解决方案
4,944 次查看
lixianghan
I try to follow this tutorial: Getting Started with TensorFlow Lite for Microcontrollers on i.MX RT to deploy flowers classification model in i.MX RT1050-EVKB. I test the generated .tflite model following the tutorial, and get correct inference result. But I can not get correct inference result after converted .tflite to .h with xxd, and deploy it in i.MX RT1050-EVKB.
1 解答
4,930 次查看
lixianghan
Thank you for your help! I solved this problem.
The correct python script:
import cv2
import numpy as np
img = cv2.imread('daisy.bmp')
img = cv2.resize(img, (128, 128))
img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
with open('daisy.h', 'w') as fout:
    print('#define STATIC_IMAGE_NAME "daisy"', file=fout)
    print('const char daisy_bmp[] = {', file=fout)
    img.tofile(fout, ', ', '0x%02X')
    print('};\n', file=fout)
The ; in the last is important.
在原帖中查看解决方案
3 回复数
4,927 次查看
david_piskula
Great! Sorry about the missing semicolon. We will make sure to update the lab guide conversion, thanks for trying it out and letting us know about it.
Have fun with eIQ.
David
4,933 次查看
david_piskula
Hello @lixianghan,
thank you for your interest in eIQ. Could you please try converting your flower image with the following python script instead of xxd?:
    import cv2
    import numpy as np
    img = cv2.imread('flower.bmp')
    with open('image_data.h', 'w') as fout:
      print('static const uint8_t image_data[] = {', file=fout)
      print('}\n', file=fout)
David
4,930 次查看
lixianghan
import cv2
import numpy as np
