With examples provided to run Zephyr on i.MX93 Cortex-A55, I am able to build hello_world and run on DDR via u-boot prompt.
I want to avoid using u-boot. I referred ATF code, but there is only support to build bl31, I want to achieve "BootROM -> ATF BL2 -> ATF BL31 -> Zephyr", any reference to build BL2 ?
Also I want to run hello_world example on OCRAM, can you provide the steps and do we also require bootloader here or can we directly load binary to OCRAM via JTAG.
