Zephyr + CAN on FRDM-MCXN947, Bitrate out of spec / Clocks
ソリューションへジャンプ
462件の閲覧回数
mwagner1
Hi @all,
I'm currently in the process of evaluating a new SoC for a project. For this i have the FRDM-MCXN947 evalboard. This includes a CAN-FD port. Please be aware that I'm new to Zephyr / MCXN.
On evaluating the CAN IP, i was unable to communicate with other devices. On checking with the scope, i've found that the bitrate is way out of spec (118kBit / 125kBit, 943kBit / 1000kBit). This is with my test application and the zephyr example (west flash frdm_mcxn947/mcxn947/cpu0 zephyr/samples/drivers/can/babbling/) so I would assume some kind of clock setup problem.
I've found the (seemingly) relevant parts as part of the evaboard (board.c) and the devicetree nxp_mcxnx4x_common.dtsi
#if DT_NODE_HAS_STATUS_OKAY(DT_NODELABEL(flexcan0))
CLOCK_SetClkDiv(kCLOCK_DivFlexcan0Clk, 1U);
CLOCK_AttachClk(kFRO_HF_to_FLEXCAN0);
#endif
flexcan0: can@d4000 {
compatible = "nxp,flexcan";
reg = <0xd4000 0x4000>;
interrupts = <62 0>;
interrupt-names = "common";
clocks = <&syscon MCUX_FLEXCAN0_CLK>;
clk-source = <0>;
status = "disabled";
None of the labels seem to be part of the zephyr OS. Can you give me a hint how to set this up correctly ?
Thank you for your help!
256件の閲覧回数
mwagner1
thanks, this fixes the problem for me.
CLOCK_SetClkDiv(kCLOCK_DivFlexcan0Clk, 3U);
CLOCK_AttachClk(kPLL0_to_FLEXCAN0);
#endif
5 返答(返信)
407件の閲覧回数
Harry_Zhang
Hi @mwagner1
You can try to add frdm_mcxn947.overlay file
&flexcan0 {
    status = "okay";
    clock-frequency = <48000000>;
    bitrate = <125000>;
    sample-point = <875>;
    bus-speed-data = <1000000>;
    sample-point-data = <750>;
Harry
357件の閲覧回数
mwagner1
this gives me compilation errors for the dt.
devicetree error: 'clock-frequency' appears in /soc/peripheral@50000000/can@d4000 in /home/user/project/build/zephyr/zephyr.dts.pre, but is not declared in 'properties:' in /home/user/project/zephyr/dts/bindings/can/nxp,flexcan.yaml
the following compiles, but the bitrate is still wrong.
&flexcan0 {
status = "okay";
// clock-frequency = <48000000>;
bitrate = <125000>;
// bus-speed-data = <1000000>;
// sample-point-data = <750>;
307件の閲覧回数
Harry_Zhang
Hi @mwagner1
I have confirmed with the internal team. this bitrate accuracy issue is caused by the clock source.  The file frdm_mcxn947/board.c configures the clocks for the board, and is clocking from the internal FRO.  It is expected that applications and custom boards will customize this board.c file as needed, see Clock Configuration in Zephyr .
There is also an open pull request enabling CAN FD support for this board at https://github.com/zephyrproject-rtos/zephyr/pull/98900 , and that PR is modifying board.c to clock from PLL0 instead to achieve the required accuracy.
You can refer to it.
Harry
257件の閲覧回数
mwagner1
#endif
333件の閲覧回数
Harry_Zhang
Hi @mwagner1
I'm sorry, I can reproduce this issue. I think it's a clock issue.
I need to discuss it with the internal team and I will inform you promptly if there is any news.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2259706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXN947%20%E4%B8%8A%E3%81%AE%20Zephyr%20%2B%20CAN%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%8C%E4%BB%95%E6%A7%98%E5%A4%96%20%2F%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12881%22%20target%3D%22_blank%22%3E%E3%81%BF%E3%82%93%E3%81%AA%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E7%94%A8%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20SoC%20%E3%82%92%E8%A9%95%E4%BE%A1%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81FRDM-MCXN947%20%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%20CAN-FD%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%20Zephyr%20%2F%20MCXN%20%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%81%94%E4%BA%86%E6%89%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3ECAN%20IP%20%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%8C%E4%BB%95%E6%A7%98%E3%81%8B%E3%82%89%E5%A4%A7%E3%81%8D%E3%81%8F%E5%A4%96%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20(118kBit%20%2F%20125kBit%E3%80%81943kBit%20%2F%201000kBit)%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%20Zephyr%20%E3%81%AE%E4%BE%8B%20(west%20flash%20%3CSPAN%3Efrdm_mcxn947%2Fmcxn947%2Fcpu0%20Zephyr%2Fsamples%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2FCAN%2Fbabbling%2F)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E9%83%A8%E5%93%81%E3%82%92%E3%80%81evaboard%20(board.c)%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BCnxp_mcxnx4x_common.dtsi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%23DT_NODE_HAS_STATUS_OKAY(DT_NODELABEL(flexcan0))%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3ECLOCK_SetClkDiv(kCLOCK_DivFlexcan0Clk%E3%80%811U)%3B%3CBR%20%2F%3E%20CLOCK_AttachClk(kFRO_HF_to_FLEXCAN0)%3B%3CBR%20%2F%3E%20%23endif%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eflexcan0%3A%20can%40d4000%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22nxp%E3%80%81flexcan%22%3B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0xd4000%200x4000%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%26lt%3B62%200%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E5%90%8D%20%3D%20%22common%22%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bsyscon%20MCUX_FLEXCAN0_CLK%26gt%3B%3B%3CBR%20%2F%3E%20clk-source%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AE%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%82%20Zephyr%20OS%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2261000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Zephyr%20%2B%20CAN%20on%20FRDM-MCXN947%2C%20Bitrate%20out%20of%20spec%20%2F%20Clocks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257905%22%20target%3D%22_blank%22%3E%40mwagner1%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Efrdm_mcxn947.overlay%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bflexcan0%20%7B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20clock-frequency%20%3D%20%26lt%3B48000000%26gt%3B%3B%0A%20%20%20%20bitrate%20%3D%20%26lt%3B125000%26gt%3B%3B%0A%20%20%20%20sample-point%20%3D%20%26lt%3B875%26gt%3B%3B%0A%20%20%20%20bus-speed-data%20%3D%20%26lt%3B1000000%26gt%3B%3B%0A%20%20%20%20sample-point-data%20%3D%20%26lt%3B750%26gt%3B%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Zephyr%20%2B%20CAN%20on%20FRDM-MCXN947%2C%20Bitrate%20out%20of%20spec%20%2F%20Clocks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81dt%20%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fhome%2Fuser%2Fproject%2Fbuild%2FZephyr%2Fzephyr.dts.pre%20%E3%81%AE%20%2Fsoc%2Fperipheral%4050000000%2Fcan%40d4000%20%E3%81%AB%20'clock-frequency'%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%2Fhome%2Fuser%2Fproject%2Fzephyr%2Fdts%2Fbindings%2Fcan%2Fnxp%2Cflexcan.yaml%20%E3%81%AE%20'properties%3A'%20%E3%81%A7%E3%81%AF%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E3%81%BE%E3%81%A0%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bflexcan0%20%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%2F%2F%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B48000000%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B125000%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B875%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%2F%2F%20%E3%83%90%E3%82%B9%E9%80%9F%E5%BA%A6%E3%83%87%E3%83%BC%E3%82%BF%20%3D%20%26lt%3B1000000%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%2F%2F%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%20%3D%20%26lt%3B750%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Zephyr%20%2B%20CAN%20on%20FRDM-MCXN947%2C%20Bitrate%20out%20of%20spec%20%2F%20Clocks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257905%22%20target%3D%22_blank%22%3E%40mwagner1%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BECAN%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E6%99%82%E8%A8%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A4%BE%E5%86%85%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E5%8D%94%E8%AD%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%95%E3%81%8B%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%99%E3%81%90%E3%81%AB%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Zephyr%20%2B%20CAN%20on%20FRDM-MCXN947%2C%20Bitrate%20out%20of%20spec%20%2F%20Clocks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%23DT_NODE_HAS_STATUS_OKAY(DT_NODELABEL(flexcan0))%20%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ECLOCK_SetClkDiv(kCLOCK_DivFlexcan0Clk%E3%80%813U)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ECLOCK_AttachClk(kPLL0_to_FLEXCAN0)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%23endif%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Zephyr%20%2B%20CAN%20on%20FRDM-MCXN947%2C%20Bitrate%20out%20of%20spec%20%2F%20Clocks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257905%22%20target%3D%22_blank%22%3E%40mwagner1%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%A4%BE%E5%86%85%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E7%B2%BE%E5%BA%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fe6fd157a93db7297583d7b93f9a74c0e0977bc95%2Fboards%2Fnxp%2Ffrdm_mcxn947%2Fboard.c%23L295%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Efrdm_mcxn947%2Fboard.c%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E5%86%85%E9%83%A8%20FRO%20%E3%81%8B%E3%82%89%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82c%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FZephyr-Project-Knowledge-Base%2FClock-Configuration-in-Zephyr%2Fta-p%2F2166958%22%20target%3D%22_self%22%3EZephyr%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%82%92%3C%2FA%3E%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fpull%2F98900%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fpull%2F98900%3C%2FA%3E%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%20CAN%20FD%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%20%E3%83%97%E3%83%AB%20%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%82%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%20PR%20%E3%81%A7%E3%81%AF%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E7%B2%BE%E5%BA%A6%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20PLL0%20%E3%81%8B%E3%82%89%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20board.c%20%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E9%A0%82%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
