Poor Read/Write Performance with Zephyr SDIF Driver on LPCXpresso55S69-EVK
5,266件の閲覧回数
wima88
When evaluating the LPC55S69-EVK, I noticed significantly slower read/write speeds with Zephyr’s USB mass storage (using the SDIF driver) compared to the MCUXpresso SDK example.
Benchmark Results
Below are the performance comparisons using CrystalDiskMark 8.0.6:
1. MCUXpresso SDK Example (lpcxpresso55s69_dev_msc_disk_freertos_cm33_core0)
[Read]
  SEQ 1MiB: 10.903 MB/s | RND 4KiB: 4.204 MB/s
[Write]
  SEQ 1MiB: 7.756 MB/s  | RND 4KiB: 3.286 MB/s
2. Zephyr (Legacy USB Stack)
[Read]
  SEQ 1MiB: 1.048 MB/s | RND 4KiB: 0.985 MB/s
[Write]
  SEQ 1MiB: 0.209 MB/s | RND 4KiB: 0.351 MB/s
 ~10x slower than MCUXpresso SDK.
3. Zephyr (USB Device Next Stack)
[Read]
  SEQ 1MiB: 1.676 MB/s | RND 4KiB: 1.489 MB/s
[Write]
  SEQ 1MiB: 0.628 MB/s | RND 4KiB: 0.830 MB/s
*Still ~5-6x slower than MCUXpresso SDK.*
Debugging Attempts
  • Enabled Zephyr SDHC & SD card logs – no errors detected.
  • Confirmed SD card initialization (3.3V, 50MHz clock, correct block size).
  • Logs show successful SDIF clock configuration (24MHz → 50MHz).
[00:00:00.000] <dbg> sd: sd_init_io: Host controller support 3.3V max
[00:00:01.000] <dbg> sdif: mcux_sdif_set_io: SDIF clock set to 400000
[00:00:01.376] <dbg> sd: sdmmc_read_csd: Card block count 124735488, block size 512
[00:00:01.376] <dbg> sdif: mcux_sdif_set_io: SDIF clock set to 24000000
[00:00:01.379] <dbg> sd: sdmmc_set_bus_speed: Setting bus clock to: 50000000
Environment
  • Board: LPC55S69-EVK
  • Zephyr Version:  commit :c2d52c7f4b53a3e3691a7e6fa15af83ef72446cc(4.1.99)
Are their any Kconfig option or overlay that I need to modify ?
I’d appreciate any insights or suggestions to debug this further
Thanks in advance!
タグ(3)
8 返答(返信)
5,143件の閲覧回数
wima88
@Harry_Zhang  Any  Update on this issue? I tested the FRDM-MCXN947  (with Zephyr) which uses the imx driver instead of the lpc driver. and results are pretty much the same as above
5,020件の閲覧回数
Harry_Zhang
Hi @wima88
Could you please try adding the following optimizations
CONFIG_MCUX_SDIF_DMA_BUFFER_SIZE=512
CONFIG_SPEED_OPTIMIZATIONS=y
CONFIG_SDIO_STACK=y
CONFIG_MPU=n
CONFIG_ASSERT=n
CONFIG_LOG=n
CONFIG_LOG_DEFAULT_LEVEL=0
Harry
4,997件の閲覧回数
wima88
Hi Harry ,
Thanks for getting back to me. with suggested Konig options I was managed to get around 2.54 MB/s.
[Read]
SEQ 1MiB (Q= 1, T= 1): 2.516 MB/s [ 2.4 IOPS] <412859.66 us>
RND 4KiB (Q= 1, T= 1): 2.033 MB/s [ 496.3 IOPS] < 2011.94 us>
I wonder, could USB stack be the bottle neck?
4,857件の閲覧回数
Harry_Zhang
Hi @wima88
Another USB optimizations that you could give a try.
CONFIG_UDC_BUF_COUNT=128
CONFIG_UDC_WORKQUEUE_STACK_SIZE=2048
CONFIG_UDC_WORKQUEUE_PRIORITY=0
Harry
4,841件の閲覧回数
wima88
Thanks for the suggestions.
Despite all the optimizations and changes, the best I could reach was 3.1 MB/s. Have you identified the root cause of the performance issue yet? Frankly, I doubt any amount of system tuning alone will get us to full performance without addressing the underlying problem.
Wimansha
5,135件の閲覧回数
Harry_Zhang
Hi @wima88
We are investigating this issue, I will inform you as soon as there is a result.
Harry
5,242件の閲覧回数
Harry_Zhang
Hi @wima88
May i ask how to tested it?
I want to test it.
Harry
5,237件の閲覧回数
wima88
Hi Harry ,
I use CrystalDiskMark as my benchmarking tool(https://crystalmark.info/en). Here’s my setup and process:
MCUXpresso SDK Setup:
  • Modified jumper P4 voltage from 1.8V to 3.3V (as per user guide Table 1, P21).
  • Downloaded the SDK example (v25.03.00) via the MCUXpresso extension in VSCode.
  • Built and flashed the lpcxpresso55s69_dev_msc_disk_freertos_cm33_core0 example.
  • After reset, the serial terminal showed the prompt: "Please insert disk."
  • Used a SanDisk Class 3 V30 SD card.
  • Connected P9 (HS-USB) and configured CrystalDiskMark (see attached screenshot).57ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg57ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpgScreenshot 2025-06-25 105150.pngScreenshot 2025-06-25 105150.png
  • Tested with:
    • 1MB block size
    • 1 Queue, 1 Thread
    • 9 iterations of a 32MB file
Zephyr Setup:
Used the same development environment as above.
Legacy USB Stack:
  • Example: zephyr/samples/subsys/usb/mass
  • No modifications made.
  • Build command:
west build -p -b lpcxpresso55s69/lpc55s69/cpu0
west flash
USB Next Stack:
Modified next_usb_prj.conf as follows:
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_PRINTK=y
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_SDHC_LOG_LEVEL_DBG=y
CONFIG_SD_LOG_LEVEL_DBG=y
CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_USBD_MSC_STACK_SIZE=4096
CONFIG_USBD_MSC_LUNS_PER_INSTANCE=5
CONFIG_USBD_MSC_SCSI_BUFFER_SIZE=2048
Build Command
west build -p -b lpcxpresso55s69/lpc55s69/cpu0 -- -DCONF_FILE=usbd_next_prj.conf
west flash
Testing:
  • Used the same CrystalDiskMark setup for all three cases.
  • No overlay files were used in either Zephyr example.
Let me know if you need any further details!
Thank You
タグ(3)
%3CLINGO-SUB%20id%3D%22lingo-sub-2122450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPCXpresso55S69-EVK%20%E3%81%AE%20Zephyr%20SDIF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%8E%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2122450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FLPC55S69-EVK%2Fpd-p%2FLPC55S69-EVK%22%20class%3D%22lia-product-mention%22%20data-product%3D%223114-1%22%20target%3D%22_blank%22%3ELPC55S69-EVK%3C%2FA%3E%3C%2FSPAN%3E%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81Zephyr%E3%81%AEUSB%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%EF%BC%88SDIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%EF%BC%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%E3%81%8C%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EMCUXpresso%20SDK%20%E3%81%AE%E4%BE%8B%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-174012498%22%20id%3D%22toc-hId-204605068%22%3E%3CSTRONG%3E%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E7%B5%90%E6%9E%9C%3C%2FSTRONG%3E%3C%2FH4%3E%3CP%20class%3D%22%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%9E%E3%83%BC%E3%82%AF%208.0.6%3C%2FSTRONG%3E%20%3A%3C%2FP%3E%3CH5%20id%3D%22toc-hId-864573972%22%20id%3D%22toc-hId-895166542%22%3E%3CSTRONG%3E1.%20MCUXpresso%20SDK%20%E3%81%AE%E4%BE%8B%20(%3C%2FSTRONG%3E%20%3CSTRONG%3Elpcxpresso55s69_dev_msc_disk_freertos_cm33_core0)%3C%2FSTRONG%3E%3C%2FH5%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0A%20%20SEQ%201MiB%3A%2010.903%20MB%2Fs%20%7C%20RND%204KiB%3A%204.204%20MB%2Fs%0A%5BWrite%5D%0A%20%20SEQ%201MiB%3A%207.756%20MB%2Fs%20%20%7C%20RND%204KiB%3A%203.286%20MB%2Fs%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CH5%20id%3D%22toc-hId--942880491%22%20id%3D%22toc-hId--912287921%22%3E%3CSTRONG%3E2.%20Zephyr%EF%BC%88%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BCUSB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%EF%BC%89%3C%2FSTRONG%3E%3C%2FH5%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0A%20%20SEQ%201MiB%3A%201.048%20MB%2Fs%20%7C%20RND%204KiB%3A%200.985%20MB%2Fs%0A%5BWrite%5D%0A%20%20SEQ%201MiB%3A%200.209%20MB%2Fs%20%7C%20RND%204KiB%3A%200.351%20MB%2Fs%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CEM%3EMCUXpresso%20SDK%20%E3%82%88%E3%82%8A%E3%82%82%E7%B4%84%2010%20%E5%80%8D%E9%81%85%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId-1544632342%22%20id%3D%22toc-hId-1575224912%22%3E%3CSTRONG%3E3.%20Zephyr%EF%BC%88USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8D%E3%82%AF%E3%82%B9%E3%83%88%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%EF%BC%89%3C%2FSTRONG%3E%3C%2FH5%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0A%20%20SEQ%201MiB%3A%201.676%20MB%2Fs%20%7C%20RND%204KiB%3A%201.489%20MB%2Fs%0A%5BWrite%5D%0A%20%20SEQ%201MiB%3A%200.628%20MB%2Fs%20%7C%20RND%204KiB%3A%200.830%20MB%2Fs%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%80%81MCUXpresso%20SDKs%20%E3%82%88%E3%82%8A%205%20%EF%BD%9E%206%20%E5%80%8D%E9%81%85%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId-1534129238%22%20id%3D%22toc-hId-1564721808%22%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E8%A9%A6%E3%81%BF%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E6%9C%89%E5%8A%B9%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EZephyr%20SDHC%20%26amp%3B%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AD%E3%82%B0%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E2%80%93%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3ESD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(3.3V%E3%80%8150MHz%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B5%E3%82%A4%E3%82%BA)%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81SDIF%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(24MHz%20%E2%86%92%2050MHz)%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A00%3A00.000%5D%20%3CDBG%3E%20sd%3A%20sd_init_io%3A%20Host%20controller%20support%203.3V%20max%20%20%0A%5B00%3A00%3A01.000%5D%20%3CDBG%3E%20sdif%3A%20mcux_sdif_set_io%3A%20SDIF%20clock%20set%20to%20400000%20%20%0A%5B00%3A00%3A01.376%5D%20%3CDBG%3E%20sd%3A%20sdmmc_read_csd%3A%20Card%20block%20count%20124735488%2C%20block%20size%20512%20%20%0A%5B00%3A00%3A01.376%5D%20%3CDBG%3E%20sdif%3A%20mcux_sdif_set_io%3A%20SDIF%20clock%20set%20to%2024000000%20%20%0A%5B00%3A00%3A01.379%5D%20%3CDBG%3E%20sd%3A%20sdmmc_set_bus_speed%3A%20Setting%20bus%20clock%20to%3A%2050000000%20%20%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CH4%20id%3D%22toc-hId--273325225%22%20id%3D%22toc-hId--242732655%22%3E%3CSTRONG%3E%E7%92%B0%E5%A2%83%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%3C%2FSTRONG%3E%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FLPC55S69-EVK%2Fpd-p%2FLPC55S69-EVK%22%20class%3D%22lia-product-mention%22%20data-product%3D%223114-2%22%20target%3D%22_blank%22%3ELPC55S69-EVK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3EZephyr%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3C%2FSTRONG%3E%3CSPAN%3E%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%3Ac2d52c7f4b53a3e3691a7e6fa15af83ef72446cc(4.1.99)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%20Kconfig%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%93%E3%82%8C%E3%82%92%E3%81%95%E3%82%89%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%B4%9E%E5%AF%9F%E3%82%84%E6%8F%90%E6%A1%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8F%90%E6%A1%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%A8%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%9C%80%E9%AB%98%E9%80%9F%E5%BA%A6%E3%81%AF%203.1%20MB%2F%E7%A7%92%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E7%8E%87%E7%9B%B4%E3%81%AB%E8%A8%80%E3%81%A3%E3%81%A6%E3%80%81%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E8%AA%BF%E6%95%B4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A6%E3%82%A3%E3%83%9E%E3%83%B3%E3%82%B7%E3%83%A3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E5%88%A5%E3%81%AE%20USB%20%E6%9C%80%E9%81%A9%E5%8C%96%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-java%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_UDC_BUF_COUNT%3D128%0ACONFIG_UDC_WORKQUEUE_STACK_SIZE%3D2048%0ACONFIG_UDC_WORKQUEUE_PRIORITY%3D0%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Konig%20%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%B4%84%202.54%20MB%2F%E7%A7%92%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0ASEQ%201MiB%20(Q%3D%201%2C%20T%3D%201)%3A%202.516%20MB%2Fs%20%5B%202.4%20IOPS%5D%20%26lt%3B412859.66%20us%26gt%3B%0ARND%204KiB%20(Q%3D%201%2C%20T%3D%201)%3A%202.033%20MB%2Fs%20%5B%20496.3%20IOPS%5D%20%26lt%3B%202011.94%20us%26gt%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EUSB%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E3%83%9C%E3%83%88%E3%83%AB%E3%83%8D%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%AF%E3%81%84%E3%81%8B%E3%81%8C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_MCUX_SDIF_DMA_BUFFER_SIZE%3D512%0ACONFIG_SPEED_OPTIMIZATIONS%3Dy%0ACONFIG_SDIO_STACK%3Dy%0ACONFIG_MPU%3Dn%0ACONFIG_ASSERT%3Dn%0ACONFIG_LOG%3Dn%0ACONFIG_LOG_DEFAULT_LEVEL%3D0%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2129971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2129971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%AA%BF%E6%9F%BB%E4%B8%AD%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%8C%E5%87%BA%E6%AC%A1%E7%AC%AC%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2129415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2129415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E4%BD%95%E3%81%8B%E6%9B%B4%E6%96%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3Flpc%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20imx%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FFRDM-MCXN947%2Fpd-p%2FFRDM-MCXN947%22%20class%3D%22lia-product-mention%22%20data-product%3D%222740-1%22%20target%3D%22_blank%22%3EFRDM-MCXN947%3C%2FA%3E%20(Zephyr%20%E4%BB%98%E3%81%8D)%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B5%90%E6%9E%9C%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%A8%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123270%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123270%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%A7%81%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%9E%E3%83%BC%E3%82%AF%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%A7%81%E3%81%AE%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6(%20%3CA%20href%3D%22https%3A%2F%2Fcrystalmark.info%2Fen%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fcrystalmark.info%2Fen%3C%2FA%3E%20)%E3%80%82%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1970991788%22%20id%3D%22toc-hId--253235759%22%3E%3CSTRONG%3EMCUXpresso%20SDKs%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E6%94%B9%E9%80%A0%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EP4%E9%9B%BB%E5%9C%A71.8V%EF%BD%9E3.3V%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E8%A1%A81%E3%80%81P21%E3%81%AB%E3%82%88%E3%82%8B)%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ESDK%E3%81%AE%E4%BE%8B%EF%BC%88v25.03.00%EF%BC%89%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%B5%8C%E7%94%B1%E3%81%A7%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EVSCode%20%E3%81%AE%20MCUXpresso%20%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Elpcxpresso55s69_dev_msc_disk_freertos_cm33_core0%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%BE%8B%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%AB%AF%E6%9C%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3E%E3%80%8C%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%3C%2FEM%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ESanDisk%20%E3%82%AF%E3%83%A9%E3%82%B9%203%20V30%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EP9%EF%BC%88HS-USB%EF%BC%89%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%A7%8B%E6%88%90%E6%B8%88%E3%81%BF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%9E%E3%83%BC%E3%82%AF%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(%E6%B7%BB%E4%BB%98%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344664iED20FDC457B00A58%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20alt%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E57ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-06-25%20105150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-06-25%20105150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344665i3E93899693170A99%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-06-25%20105150.png%22%20alt%3D%22Screenshot%202025-06-25%20105150.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202025-06-25%20105150.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%83%86%E3%82%B9%E3%83%88%E5%AF%BE%E8%B1%A1%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E1MB%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E1%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%80%811%20Thread%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E32MB%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE9%E5%9B%9E%E3%81%AE%E5%8F%8D%E5%BE%A9%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-163537325%22%20id%3D%22toc-hId--2060690222%22%3E%3CSTRONG%3EZephyr%20%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3A%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%20class%3D%22%22%3E%E4%B8%8A%E8%A8%98%E3%81%A8%E5%90%8C%E3%81%98%E9%96%8B%E7%99%BA%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-854098799%22%20id%3D%22toc-hId--1370128748%22%3E%3CSTRONG%3E%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%20USB%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3A%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%BE%8B%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EZephyr%2F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%2F%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2FUSB%2F%E8%B3%AA%E9%87%8F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%A4%89%E6%9B%B4%E3%81%AF%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ewest%20build%20-p%20-b%20lpcxpresso55s69%2Flpc55s69%2Fcpu0%0Awest%20flash%3C%2FCODE%3E%3C%2FPRE%3E%3CH4%20id%3D%22toc-hId--953355664%22%20id%3D%22toc-hId-1117384085%22%3E%3CSTRONG%3EUSB%20%E3%83%8D%E3%82%AF%E3%82%B9%E3%83%88%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3A%3C%2FSTRONG%3E%3C%2FH4%3E%3CP%20class%3D%22%22%3E%E4%BF%AE%E6%AD%A3%E6%B8%88%E3%81%BF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Enext_usb_prj.conf%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_DISK_ACCESS%3Dy%20%20%0ACONFIG_FILE_SYSTEM%3Dy%20%20%0ACONFIG_FAT_FILESYSTEM_ELM%3Dy%20%20%0ACONFIG_PRINTK%3Dy%20%20%0A%0ACONFIG_DISK_DRIVERS%3Dy%20%20%0ACONFIG_DISK_DRIVER_SDMMC%3Dy%20%20%0A%0ACONFIG_SDHC_LOG_LEVEL_DBG%3Dy%20%20%0ACONFIG_SD_LOG_LEVEL_DBG%3Dy%20%20%0ACONFIG_LOG_BUFFER_SIZE%3D2048%20%20%0A%0ACONFIG_USBD_MSC_STACK_SIZE%3D4096%20%20%0ACONFIG_USBD_MSC_LUNS_PER_INSTANCE%3D5%20%20%0ACONFIG_USBD_MSC_SCSI_BUFFER_SIZE%3D2048%20%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ewest%20build%20-p%20-b%20lpcxpresso55s69%2Flpc55s69%2Fcpu0%20--%20-DCONF_FILE%3Dusbd_next_prj.conf%20%20%0Awest%20flash%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--963858768%22%20id%3D%22toc-hId-411717502%22%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%3A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E5%90%8C%E3%81%98CrystalDiskMark%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E3%E3%81%A4%E3%81%AECASE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E5%BD%93%E3%81%A6%E3%81%AF%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AA%E3%81%97%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%20Zephyr%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%84%E6%83%85%E5%A0%B1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
