Poor Read/Write Performance with Zephyr SDIF Driver on LPCXpresso55S69-EVK
1,714 次查看
wima88
When evaluating the LPC55S69-EVK, I noticed significantly slower read/write speeds with Zephyr’s USB mass storage (using the SDIF driver) compared to the MCUXpresso SDK example.
Benchmark Results
Below are the performance comparisons using CrystalDiskMark 8.0.6:
1. MCUXpresso SDK Example (lpcxpresso55s69_dev_msc_disk_freertos_cm33_core0)
[Read]
  SEQ 1MiB: 10.903 MB/s | RND 4KiB: 4.204 MB/s
[Write]
  SEQ 1MiB: 7.756 MB/s  | RND 4KiB: 3.286 MB/s
2. Zephyr (Legacy USB Stack)
[Read]
  SEQ 1MiB: 1.048 MB/s | RND 4KiB: 0.985 MB/s
[Write]
  SEQ 1MiB: 0.209 MB/s | RND 4KiB: 0.351 MB/s
 ~10x slower than MCUXpresso SDK.
3. Zephyr (USB Device Next Stack)
[Read]
  SEQ 1MiB: 1.676 MB/s | RND 4KiB: 1.489 MB/s
[Write]
  SEQ 1MiB: 0.628 MB/s | RND 4KiB: 0.830 MB/s
*Still ~5-6x slower than MCUXpresso SDK.*
Debugging Attempts
  • Enabled Zephyr SDHC & SD card logs – no errors detected.
  • Confirmed SD card initialization (3.3V, 50MHz clock, correct block size).
  • Logs show successful SDIF clock configuration (24MHz → 50MHz).
[00:00:00.000] <dbg> sd: sd_init_io: Host controller support 3.3V max
[00:00:01.000] <dbg> sdif: mcux_sdif_set_io: SDIF clock set to 400000
[00:00:01.376] <dbg> sd: sdmmc_read_csd: Card block count 124735488, block size 512
[00:00:01.376] <dbg> sdif: mcux_sdif_set_io: SDIF clock set to 24000000
[00:00:01.379] <dbg> sd: sdmmc_set_bus_speed: Setting bus clock to: 50000000
Environment
  • Board: LPC55S69-EVK
  • Zephyr Version:  commit :c2d52c7f4b53a3e3691a7e6fa15af83ef72446cc(4.1.99)
Are their any Kconfig option or overlay that I need to modify ?
I’d appreciate any insights or suggestions to debug this further
Thanks in advance!
标记 (3)
8 回复数
1,591 次查看
wima88
@Harry_Zhang  Any  Update on this issue? I tested the FRDM-MCXN947  (with Zephyr) which uses the imx driver instead of the lpc driver. and results are pretty much the same as above
1,468 次查看
Harry_Zhang
Hi @wima88
Could you please try adding the following optimizations
CONFIG_MCUX_SDIF_DMA_BUFFER_SIZE=512
CONFIG_SPEED_OPTIMIZATIONS=y
CONFIG_SDIO_STACK=y
CONFIG_MPU=n
CONFIG_ASSERT=n
CONFIG_LOG=n
CONFIG_LOG_DEFAULT_LEVEL=0
Harry
1,445 次查看
wima88
Hi Harry ,
Thanks for getting back to me. with suggested Konig options I was managed to get around 2.54 MB/s.
[Read]
SEQ 1MiB (Q= 1, T= 1): 2.516 MB/s [ 2.4 IOPS] <412859.66 us>
RND 4KiB (Q= 1, T= 1): 2.033 MB/s [ 496.3 IOPS] < 2011.94 us>
I wonder, could USB stack be the bottle neck?
1,305 次查看
Harry_Zhang
Hi @wima88
Another USB optimizations that you could give a try.
CONFIG_UDC_BUF_COUNT=128
CONFIG_UDC_WORKQUEUE_STACK_SIZE=2048
CONFIG_UDC_WORKQUEUE_PRIORITY=0
Harry
1,289 次查看
wima88
Thanks for the suggestions.
Despite all the optimizations and changes, the best I could reach was 3.1 MB/s. Have you identified the root cause of the performance issue yet? Frankly, I doubt any amount of system tuning alone will get us to full performance without addressing the underlying problem.
Wimansha
1,583 次查看
Harry_Zhang
Hi @wima88
We are investigating this issue, I will inform you as soon as there is a result.
Harry
1,690 次查看
Harry_Zhang
Hi @wima88
May i ask how to tested it?
I want to test it.
Harry
1,685 次查看
wima88
Hi Harry ,
I use CrystalDiskMark as my benchmarking tool(https://crystalmark.info/en). Here’s my setup and process:
MCUXpresso SDK Setup:
  • Modified jumper P4 voltage from 1.8V to 3.3V (as per user guide Table 1, P21).
  • Downloaded the SDK example (v25.03.00) via the MCUXpresso extension in VSCode.
  • Built and flashed the lpcxpresso55s69_dev_msc_disk_freertos_cm33_core0 example.
  • After reset, the serial terminal showed the prompt: "Please insert disk."
  • Used a SanDisk Class 3 V30 SD card.
  • Connected P9 (HS-USB) and configured CrystalDiskMark (see attached screenshot).57ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpgScreenshot 2025-06-25 105150.png
  • Tested with:
    • 1MB block size
    • 1 Queue, 1 Thread
    • 9 iterations of a 32MB file
Zephyr Setup:
Used the same development environment as above.
Legacy USB Stack:
  • Example: zephyr/samples/subsys/usb/mass
  • No modifications made.
  • Build command:
west build -p -b lpcxpresso55s69/lpc55s69/cpu0
west flash
USB Next Stack:
Modified next_usb_prj.conf as follows:
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_PRINTK=y
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_SDHC_LOG_LEVEL_DBG=y
CONFIG_SD_LOG_LEVEL_DBG=y
CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_USBD_MSC_STACK_SIZE=4096
CONFIG_USBD_MSC_LUNS_PER_INSTANCE=5
CONFIG_USBD_MSC_SCSI_BUFFER_SIZE=2048
Build Command
west build -p -b lpcxpresso55s69/lpc55s69/cpu0 -- -DCONF_FILE=usbd_next_prj.conf
west flash
Testing:
  • Used the same CrystalDiskMark setup for all three cases.
  • No overlay files were used in either Zephyr example.
Let me know if you need any further details!
Thank You
标记 (3)
%3CLINGO-SUB%20id%3D%22lingo-sub-2122450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20LPCXpresso55S69-EVK%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20Zephyr%20SDIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E8%AF%BB%E5%86%99%E6%80%A7%E8%83%BD%E4%B8%8D%E4%BD%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2122450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E5%9C%A8%E8%AF%84%E4%BC%B0%3CSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FLPC55S69-EVK%2Fpd-p%2FLPC55S69-EVK%22%20class%3D%22lia-product-mention%22%20data-product%3D%223114-1%22%20target%3D%22_blank%22%3ELPC55S69-EVK%3C%2FA%3E%3C%2FSPAN%3E%20%E6%97%B6%EF%BC%8C%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E4%B8%8E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3EMCUXpresso%20SDK%20%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%E7%9B%B8%E6%AF%94%EF%BC%8CZephyr%20%E7%9A%84%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E5%99%A8%EF%BC%88%E4%BD%BF%E7%94%A8%20SDIF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E7%9A%84%E8%AF%BB%2F%E5%86%99%E9%80%9F%E5%BA%A6%E6%98%8E%E6%98%BE%E8%BE%83%E6%85%A2%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-174012498%22%20id%3D%22toc-hId-204605103%22%3E%3CSTRONG%3E%E5%9F%BA%E5%87%86%E7%BB%93%E6%9E%9C%3C%2FSTRONG%3E%3C%2FH4%3E%3CP%20class%3D%22%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%BD%BF%E7%94%A8%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3ECrystalDiskMark%208.0.6%3C%2FSTRONG%3E%20%E8%BF%9B%E8%A1%8C%E7%9A%84%E6%80%A7%E8%83%BD%E6%AF%94%E8%BE%83%EF%BC%9A%3C%2FP%3E%3CH5%20id%3D%22toc-hId-864573972%22%20id%3D%22toc-hId-895166577%22%3E%3CSTRONG%3E1.MCUXpresso%20SDK%20%E7%A4%BA%E4%BE%8B%20(%3C%2FSTRONG%3E%3CSTRONG%3Elpcxpresso55s69_dev_msc_disk_freertos_cm33_core0)%3C%2FSTRONG%3E%3C%2FH5%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0A%20%20SEQ%201MiB%3A%2010.903%20MB%2Fs%20%7C%20RND%204KiB%3A%204.204%20MB%2Fs%0A%5BWrite%5D%0A%20%20SEQ%201MiB%3A%207.756%20MB%2Fs%20%20%7C%20RND%204KiB%3A%203.286%20MB%2Fs%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CH5%20id%3D%22toc-hId--942880491%22%20id%3D%22toc-hId--912287886%22%3E%3CSTRONG%3E2.Zephyr%EF%BC%88%E4%BC%A0%E7%BB%9F%20USB%20%E5%A0%86%E6%A0%88%EF%BC%89%3C%2FSTRONG%3E%3C%2FH5%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0A%20%20SEQ%201MiB%3A%201.048%20MB%2Fs%20%7C%20RND%204KiB%3A%200.985%20MB%2Fs%0A%5BWrite%5D%0A%20%20SEQ%201MiB%3A%200.209%20MB%2Fs%20%7C%20RND%204KiB%3A%200.351%20MB%2Fs%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%20%3CEM%3E%E6%AF%94%20MCUXpresso%20SDK%20%E6%85%A2%20~10%20%E5%80%8D%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId-1544632342%22%20id%3D%22toc-hId-1575224947%22%3E%3CSTRONG%3E3.Zephyr%EF%BC%88USB%20%E8%AE%BE%E5%A4%87%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%A0%86%E6%A0%88%EF%BC%89%3C%2FSTRONG%3E%3C%2FH5%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0A%20%20SEQ%201MiB%3A%201.676%20MB%2Fs%20%7C%20RND%204KiB%3A%201.489%20MB%2Fs%0A%5BWrite%5D%0A%20%20SEQ%201MiB%3A%200.628%20MB%2Fs%20%7C%20RND%204KiB%3A%200.830%20MB%2Fs%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%E4%BB%8D%E6%AF%94%20MCUXpresso%20SDK%20%E6%85%A2%20~5-6%20%E5%80%8D%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId-1534129238%22%20id%3D%22toc-hId-1564721843%22%3E%3CSTRONG%3E%E8%B0%83%E8%AF%95%E5%B0%9D%E8%AF%95%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%B7%B2%E5%90%AF%E7%94%A8%3CSPAN%3E%20%3C%2FSPAN%3E%20Zephyr%3CSTRONG%3ESDHC%26amp%3B%20SD%20%E5%8D%A1%E6%97%A5%E5%BF%97%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E-%20%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E7%A1%AE%E8%AE%A4%20SD%20%E5%8D%A1%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%883.3V%E3%80%8150MHz%20%E6%97%B6%E9%92%9F%E3%80%81%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%9D%97%E5%A4%A7%E5%B0%8F%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%20SDIF%20%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E6%88%90%E5%8A%9F%EF%BC%8824MHz%20%E2%86%92%2050MHz%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A00%3A00.000%5D%20%3CDBG%3E%20sd%3A%20sd_init_io%3A%20Host%20controller%20support%203.3V%20max%20%20%0A%5B00%3A00%3A01.000%5D%20%3CDBG%3E%20sdif%3A%20mcux_sdif_set_io%3A%20SDIF%20clock%20set%20to%20400000%20%20%0A%5B00%3A00%3A01.376%5D%20%3CDBG%3E%20sd%3A%20sdmmc_read_csd%3A%20Card%20block%20count%20124735488%2C%20block%20size%20512%20%20%0A%5B00%3A00%3A01.376%5D%20%3CDBG%3E%20sdif%3A%20mcux_sdif_set_io%3A%20SDIF%20clock%20set%20to%2024000000%20%20%0A%5B00%3A00%3A01.379%5D%20%3CDBG%3E%20sd%3A%20sdmmc_set_bus_speed%3A%20Setting%20bus%20clock%20to%3A%2050000000%20%20%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CH4%20id%3D%22toc-hId--273325225%22%20id%3D%22toc-hId--242732620%22%3E%3CSTRONG%3E%E7%8E%AF%E5%A2%83%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E6%9D%BF%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FLPC55S69-EVK%2Fpd-p%2FLPC55S69-EVK%22%20class%3D%22lia-product-mention%22%20data-product%3D%223114-2%22%20target%3D%22_blank%22%3ELPC55S69-EVK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3EZephyr%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%20%20commit%20%3Ac2d52c7f4b53a3e3691a7e6fa15af83ef72446cc(4.1.99)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%20Kconfig%20%E9%80%89%E9%A1%B9%E6%88%96%E8%A6%86%E7%9B%96%E5%B1%82%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E8%AF%95%E7%9A%84%E8%A7%81%E8%A7%A3%E6%88%96%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%90%84%E7%A7%8D%E4%BC%98%E5%8C%96%E5%92%8C%E6%9B%B4%E6%94%B9%EF%BC%8C%E6%88%91%E6%89%80%E8%83%BD%E8%BE%BE%E5%88%B0%E7%9A%84%E6%9C%80%E4%BD%B3%E9%80%9F%E5%BA%A6%E4%BB%8D%E4%B8%BA%203.1%20MB%2Fs%E3%80%82%E6%82%A8%E6%89%BE%E5%88%B0%E6%80%A7%E8%83%BD%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E4%BA%86%E5%90%97%EF%BC%9F%E5%9D%A6%E7%8E%87%E5%9C%B0%E8%AF%B4%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E8%A7%A3%E5%86%B3%E6%A0%B9%E6%9C%AC%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E6%80%80%E7%96%91%E4%BB%85%E9%9D%A0%E4%BB%BB%E4%BD%95%E7%B3%BB%E7%BB%9F%E8%B0%83%E6%95%B4%E9%83%BD%E6%97%A0%E6%B3%95%E8%AE%A9%E6%88%91%E4%BB%AC%E8%BE%BE%E5%88%B0%E6%9C%80%E4%BD%B3%E6%80%A7%E8%83%BD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%BB%B4%E6%9B%BC%E6%B2%99%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8F%A6%E4%B8%80%E7%A7%8D%20USB%20%E4%BC%98%E5%8C%96%E6%96%B9%E6%B3%95%E3%80%82%20%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-java%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_UDC_BUF_COUNT%3D128%0ACONFIG_UDC_WORKQUEUE_STACK_SIZE%3D2048%0ACONFIG_UDC_WORKQUEUE_PRIORITY%3D0%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E9%87%8C%20%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E4%BD%BF%E7%94%A8%E5%BB%BA%E8%AE%AE%E7%9A%84%20Konig%20%E9%80%89%E9%A1%B9%EF%BC%8C%E6%88%91%E7%9A%84%E9%80%9F%E5%BA%A6%E8%BE%BE%E5%88%B0%E4%BA%86%202.54%20MB%2Fs%E3%80%82%20%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BRead%5D%0ASEQ%201MiB%20(Q%3D%201%2C%20T%3D%201)%3A%202.516%20MB%2Fs%20%5B%202.4%20IOPS%5D%20%26lt%3B412859.66%20us%26gt%3B%0ARND%204KiB%20(Q%3D%201%2C%20T%3D%201)%3A%202.033%20MB%2Fs%20%5B%20496.3%20IOPS%5D%20%26lt%3B%202011.94%20us%26gt%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%83%B3%EF%BC%8C%E4%BC%9A%E4%B8%8D%E4%BC%9A%E6%98%AF%20USB%20%E6%A0%88%E9%80%A0%E6%88%90%E4%BA%86%E7%93%B6%E9%A2%88%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E4%BC%98%E5%8C%96%E5%8A%9F%E8%83%BD%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_MCUX_SDIF_DMA_BUFFER_SIZE%3D512%0ACONFIG_SPEED_OPTIMIZATIONS%3Dy%0ACONFIG_SDIO_STACK%3Dy%0ACONFIG_MPU%3Dn%0ACONFIG_ASSERT%3Dn%0ACONFIG_LOG%3Dn%0ACONFIG_LOG_DEFAULT_LEVEL%3D0%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2129971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2129971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%B0%83%E6%9F%A5%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B8%80%E6%97%A6%E6%9C%89%E7%BB%93%E6%9E%9C%EF%BC%8C%E6%88%91%E4%BC%9A%E7%AB%8B%E5%8D%B3%E9%80%9A%E7%9F%A5%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2129415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2129415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FFRDM-MCXN947%2Fpd-p%2FFRDM-MCXN947%22%20class%3D%22lia-product-mention%22%20data-product%3D%222740-1%22%20target%3D%22_blank%22%3EFRDM-MCXN947%3C%2FA%3E%EF%BC%88%E4%BD%BF%E7%94%A8%20Zephyr%EF%BC%89%EF%BC%8C%E5%AE%83%E4%BD%BF%E7%94%A8%20imx%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%80%8C%E4%B8%8D%E6%98%AF%20lpc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E7%BB%93%E6%9E%9C%E4%B8%8E%E4%B8%8A%E8%BF%B0%E5%9F%BA%E6%9C%AC%E7%9B%B8%E5%90%8C%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123270%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123270%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E9%87%8C%20%E3%80%81%20%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%88%91%E4%BD%BF%E7%94%A8%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3ECrystalDiskMark%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E4%BD%9C%E4%B8%BA%E5%9F%BA%E5%87%86%E6%B5%8B%E8%AF%95%E5%B7%A5%E5%85%B7%3CA%20href%3D%22https%3A%2F%2Fcrystalmark.info%2Fen%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E(https%3A%2F%2Fcrystalmark.info%2Fen)%3C%2FA%3E%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%92%8C%E8%BF%87%E7%A8%8B%EF%BC%9A%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1970991788%22%20id%3D%22toc-hId--253235724%22%3E%3CSTRONG%3EMCUXpresso%20SDK%20%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%BF%AE%E6%94%B9%E8%B7%B3%E7%BA%BF%3CSPAN%3E%20%3C%2FSPAN%3E%20P4%3CSTRONG%3E%E7%94%B5%E5%8E%8B%E4%BB%8E%201.8V%20%E5%8D%87%E8%87%B3%203.3V%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%20%EF%BC%88%E6%A0%B9%E6%8D%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E8%A1%A8%201%EF%BC%8CP21%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E9%80%9A%E8%BF%87VSCode%20%E4%B8%AD%E7%9A%84%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3EMCUXpresso%20%E6%89%A9%E5%B1%95%3C%2FSTRONG%3E%EF%BC%8C%E4%B8%8B%E8%BD%BD%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3ESDK%20%E7%A4%BA%E4%BE%8B%EF%BC%88v25.03.00%EF%BC%89%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E7%89%88%E6%9C%AC%E5%B9%B6%E5%88%B7%E6%96%B0%E4%BA%86%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20lpcxpresso55s69_dev_msc_disk_freertos_%20cm33_core0%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E7%A4%BA%E4%BE%8B%20%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3ERESET%E5%90%8E%EF%BC%8C%E4%B8%B2%E8%A1%8C%E7%BB%88%E7%AB%AF%E6%98%BE%E7%A4%BA%E6%8F%90%E7%A4%BA%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3E%22%E8%AF%B7%E6%8F%92%E5%85%A5%E7%A3%81%E7%9B%98%E3%80%82%22%3C%2FEM%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3ESanDisk%20Class%203%20V30%20SD%20%E5%8D%A1%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E8%BF%9E%E6%8E%A5%3CSPAN%3E%20%3C%2FSPAN%3E%20P9%3CSTRONG%3E(HS-USB)%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E5%B9%B6%E9%85%8D%E7%BD%AE%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3ECrystalDiskMark%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%20%EF%BC%88%E8%A7%81%E6%89%80%E9%99%84%E6%88%AA%E5%9B%BE%EF%BC%89%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344664iED20FDC457B00A58%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20alt%3D%2257ecc5a0-a2cc-4775-be4c-74ff59cc81ae.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-06-25%20105150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-06-25%20105150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344665i3E93899693170A99%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-06-25%20105150.png%22%20alt%3D%22Screenshot%202025-06-25%20105150.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%B7%B2%E6%B5%8B%E8%AF%95%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E1MB%20%E5%8C%BA%E5%9D%97%E5%A4%A7%E5%B0%8F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E1%20%E4%B8%AA%E9%98%9F%E5%88%97%EF%BC%8C1%20%E4%B8%AA%E7%BA%BF%E7%A8%8B%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E32MB%20%E6%96%87%E4%BB%B6%E7%9A%84%209%20%E6%AC%A1%E8%BF%AD%E4%BB%A3%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-163537325%22%20id%3D%22toc-hId--2060690187%22%3E%3CSTRONG%3EZephyr%20%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%20class%3D%22%22%3E%E4%BD%BF%E7%94%A8%E4%B8%8E%E4%B8%8A%E8%BF%B0%E7%9B%B8%E5%90%8C%E7%9A%84%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-854098799%22%20id%3D%22toc-hId--1370128713%22%3E%3CSTRONG%3E%E4%BC%A0%E7%BB%9F%20USB%20%E5%A0%86%E6%A0%88%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3CSPAN%3E%20%3C%2FSPAN%3Ezephyr%2Fsamples%2Fsubsys%2Fusb%2Fmass%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E6%9C%AA%E4%BD%9C%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E7%89%88%E6%9C%AC%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ewest%20build%20-p%20-b%20lpcxpresso55s69%2Flpc55s69%2Fcpu0%0Awest%20flash%3C%2FCODE%3E%3C%2FPRE%3E%3CH4%20id%3D%22toc-hId--953355664%22%20id%3D%22toc-hId-1117384120%22%3E%3CSTRONG%3EUSB%20%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%A0%86%E6%A0%88%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH4%3E%3CP%20class%3D%22%22%3E%E4%BF%AE%E6%94%B9%3CSPAN%3E%20%3C%2FSPAN%3Enext_usb_prj.conf%3CSPAN%3E%20%3C%2FSPAN%3E%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_DISK_ACCESS%3Dy%20%20%0ACONFIG_FILE_SYSTEM%3Dy%20%20%0ACONFIG_FAT_FILESYSTEM_ELM%3Dy%20%20%0ACONFIG_PRINTK%3Dy%20%20%0A%0ACONFIG_DISK_DRIVERS%3Dy%20%20%0ACONFIG_DISK_DRIVER_SDMMC%3Dy%20%20%0A%0ACONFIG_SDHC_LOG_LEVEL_DBG%3Dy%20%20%0ACONFIG_SD_LOG_LEVEL_DBG%3Dy%20%20%0ACONFIG_LOG_BUFFER_SIZE%3D2048%20%20%0A%0ACONFIG_USBD_MSC_STACK_SIZE%3D4096%20%20%0ACONFIG_USBD_MSC_LUNS_PER_INSTANCE%3D5%20%20%0ACONFIG_USBD_MSC_SCSI_BUFFER_SIZE%3D2048%20%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%89%88%E6%9C%AC%E5%91%BD%E4%BB%A4%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ewest%20build%20-p%20-b%20lpcxpresso55s69%2Flpc55s69%2Fcpu0%20--%20-DCONF_FILE%3Dusbd_next_prj.conf%20%20%0Awest%20flash%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--963858768%22%20id%3D%22toc-hId-411717537%22%3E%3CSTRONG%3E%E6%B5%8B%E8%AF%95%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E8%BF%99%E4%B8%89%E4%B8%AA%E6%A1%88%E4%BE%8B%E9%83%BD%E4%BD%BF%E7%94%A8%E4%BA%86%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3E%E7%9B%B8%E5%90%8C%E7%9A%84%20CrystalDiskMark%20%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E4%B8%A4%E4%B8%AA%20Zephyr%20%E7%A4%BA%E4%BE%8B%E5%9D%87%3CSTRONG%3E%E6%9C%AA%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E8%A6%86%E7%9B%96%E6%96%87%E4%BB%B6%3CSPAN%3E%20%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%81%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Poor%20Read%2FWrite%20Performance%20with%20Zephyr%20SDIF%20Driver%20on%20LPCXpresso55S69-EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243115%22%20target%3D%22_blank%22%3E%40wima88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E9%97%AE%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E6%B5%8B%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
