using ZIGBEE control bridge in coordinator mode and write a string attribute or send a string
3,194件の閲覧回数
Janson
Hi,every one !
  I'm working with jn5169 chips, I want to write a string attribute to router node using ZUI(zigbee control bridge).
 it doesn't work.
4 返答(返信)
3,159件の閲覧回数
Janson
Hi @Gavin_Jia
I'd like to write a string attribute to the node.
The type value of attribute is 0x42,so I'm trying to input some data in ZUIScreenshot 2023-06-02 at 11.43.03.png
,but it errors
3,173件の閲覧回数
Gavin_Jia
Hi @Janson ,
Thanks for contacting NXP support.
Could you provide some more detail information about your implementation? Is there an application note you following with and what are your modifications about the project. We believe with these details we can locate the problem more quickly.
Thanks in advance.
Gavin
3,107件の閲覧回数
Janson
hi,
how to send a string attribute in zigbee control bridge. If you have a demo, please share it .
3,088件の閲覧回数
Gavin_Jia
Hi @Janson ,
There is currently no available demo for string attribute sending with JN5169. The issue you are experiencing is being confirmed internally and will take some time. I really apologize for this. We will have a definite conclusion on this issue in the next days.
Gavin
