maximum Children
maximum Children
3,585件の閲覧回数
baosong_xie
The maximum number of child nodes of the coordinator (router)  to set?
4 返答(返信)
3,526件の閲覧回数
stephanie_m
The modification should not be done in the .h file, it is needed for you to modify it in the following way.
Estephania
3,564件の閲覧回数
baosong_xie
JN5189 zigbee3.0 stack
SDK_2.6.1_JN5189 middleware wireless zigbee
I found that the ZPS_CHILD_TABLE_SIZE parameter in the zps_gen.h file should set the number of child nodes,But the zps_gen.h and zps_gen.c file is a read-only file ,I want to know how to modify the parameters in the file.
For example,Modify the ZPS CHILD TABLE SIZE parameter to the maximum value.
3,576件の閲覧回数
stephanie_m
Which device are you using ? Also could you please share with me the protocol to be used?
Estephania
3,562件の閲覧回数
baosong_xie
JN5189 zigbee3.0 stack SDK_2.6.1_JN5189 middleware wireless zigbee I found that the ZPS_CHILD_TABLE_SIZE parameter in the zps_gen.h file should set the number of child nodes,But the zps_gen.h and zps_gen.c file is a read-only file ,I want to know how to modify the parameters in the file. For example,Modify the ZPS CHILD TABLE SIZE parameter to the maximum value
