kw45 get ConnParams
kw45 get ConnParams
2,602 次查看
wjw2026
bleResult_t Gap_GetConnParams(deviceId_t deviceId,uint8_t mode);
The meaning of the mode parameter,there are no detailed instructions.
3 回复数
2,572 次查看
Ricardo_Zamora
Hope you are doing well. Could you please clarify the usage in your application of this function?
How are you testing this? What SDK version are you using? Could you please tell us what SDK example are you using as a base?
Ricardo
2,557 次查看
wjw2026
Hi:
SDK version 2.12.6
SDK example:w_uart
What I want to ask is the meaning or description of the api(Gap_GetConnParams) parameter mode
2,549 次查看
Ricardo_Zamora
Ricardo
