kw41z zigbee control bridge example DEBUG print error
2,569 次查看
gustcool2
I am looking at the 'zigbee 3.0 control bridge example'
and I want to print message using 'debug_vprintf' function.
but it is not working well.
Uppercase letters are printed correctly, but lowercase letters are broken.
and sometimes it outputs normally.
I am wondering why.
thank you
标签 (2)
2,502 次查看
mario_castaneda
Hi JunTae,
How are you using the debug print function?
However, you could use the next 2 options.
   vLog_Printf ( TRACE_EXC, LOG_INFO, "\n** Control Bridge Reset** " );‍
or
DBG_vPrintf(TRUE, "APP: Watchdog timer has reset device!\r\n");‍
Mario
2,502 次查看
gustcool2
thank you for your advise.
I will use vLog_vPrintf
2,503 次查看
mario_castaneda
Hi JunTae,
or
Mario
