ZigbeeNodeControlBridge IN JN5169
1,282件の閲覧回数
Janson
When the gateway has burned down the ZigbeeNodeControlBridge firmware and added several router devices, and then re burned the ZigbeeNodeControlBridge, how to maintain all router information of the coordinator, including shortaddress, without the need to reconfigure the network
1,254件の閲覧回数
Ricardo_Zamora
Hope you are doing well.
Could you please confirm how are you loading your application?
If you are using BeyondStudio, please refer to section 3.3 Loading an Application into a Device of the BeyondStudio for NXP Installation and User Guide, there you can see on Step 4 the options for the EEPROM.
Hope this helps!
Ricardo
