Zigbee 3.0 network statistics log
2,925 次查看
BasWep
I’m wondering if there is an existing way to log the zigbee 3.0 network statistics at the control bridgeside ?
Statistics as:
Amount of node rejoins, connection lost etc….
To check how stable is the Zigbee network?
5 回复数
2,880 次查看
EduardoZamora
Hello @BasWep
I apologize for the late response.
Just to confirm, which device are you using?
Eduardo.
2,876 次查看
BasWep
Hello Eduardo,
Thank you for your feedback.
We use the KW41Z
Kind regards
Bas
2,851 次查看
EduardoZamora
Could you please confirm if ZigBee Cluster Library User Guide (inside KW41Z SDK folder > docs > wireless > Zigbee), Chapter 22 Diagnostics Cluster is useful for you? Maybe you can base your requirements on this cluster, nonetheless you may need to do your own implementation of the cluster.
Eduardo.
2,808 次查看
BasWep
@EduardoZamora
Thank you for the information, we already use LQI and RSSI of that cluster. I don’t see something like how many times of rejoins or reconnected
Kind regards,
Bas
2,783 次查看
EduardoZamora
I apologize for the inconvenience this might cause you, there may not be something implemented that could meet your requirements, but you should be able to develop your own implementation at the application level having a record of the required (and available) network/stack events and generate some logs using DBG_vPrintf() (for ZGWUI log).
Some of the available events can be found in app_zcl_event_handler.c and app_general_events_handler.c
Eduardo.
