Wireless module to communicate with Modbus device
1,625件の閲覧回数
ajit1
I am new to NXP and I am using NXP for first time. I am trying to establish an IOT application using NXP module.
My application works like this I have an Energy Meter Device which works on MODBUS RTU with 32 bit floating point.I wanted to send modbus request from NXP wifi module and Based on request send need to read response & display on web page Serially .For this typical application need below details
1) Which NXP module will be recommended for this application
2)Is there any module supporting Arduino Kind of IDE . which is support many library like Software Serial, Wifi library,Modbus RTU etc
3) Is there example code comes with these MCU for Modbus communication.
4)is there any evaluation module available??
We have purchased Rapid IOt kits which gives lot of sensor which can be easily configured and view paramter on web application..
1,541件の閲覧回数
stephanie_m
Sorry for the inconvenience this might cause you but we currently do not have a WIFI solution.
You can check our available wireless products in  the following page Wireless Solutions for Embedded Devices|NXP
Estephania
