UWB SR040
UWB SR040
2,199 次查看
kalai
    we are using UWB board SR150 and SR040 ,when connect uwb antenna board smd ( SR150) antenna we can get the data from the tag.
 if i insert the SR040 board we cant get the data, it shows error in app.
(Error like: could not start distance alert demo. if the problem persists, please try to reset the board)
so can explain the purpose of SR040 board and how to solve the issue.
thanks
kalai
2,184 次查看
Ricardo_Zamora
Hi Kalai,
Hope you are doing well. Could you please contact the person who provided you with the board?
He/she will be able to help you.
Ricardo
