Try an App on PNEV7462C without Debugg Card
1,952 次查看
amighri
After Debugging I want the card to excute an application without the Debugg Link  2 card (as described in the user guide  UM10883). How can I do that ?
Thanks in advance.
5 回复数
1,938 次查看
Fabian_R
Hello!
Thank you for you contacting us!
The MCUXpresso User Guide is mentioned in 14. The GUI Flash Tool.
Here mentions the how-to's of programming the flash on the Evaluation Boards.
Fabian
1,924 次查看
amighri
I  tried the GUI flash Tool. The operation was successful but as I take off the LPC-Link-2 the app can't be excuted. Is there a tutorial i might skipped an important Step.
Thanks in advance
1,914 次查看
Fabian_R
Hello!
You can find the guide for flashing the EEPROM memory of the PN7462 Evaluation board by following Section 8.9 Updating flash/EEPROM via the SWD interface in the Quick Start Guide. We recommend using the LPC-Link2 option for this.
Although the Guide is with the B board, the procedure is the same with the C board.
Can you clarify that this is the procedure you are following?
Fabian
1,891 次查看
amighri
Thank you very much. Another Step I was messing is also that I didn't debug with Release version.
Greetings,
@amighri
1,870 次查看
Fabian_R
It's great to know we are able to help!
Fabian
