R41Z module does freezing
1,720件の閲覧回数
somkiatup
I have a problem with R41Z module, while my example process was installed in factory. I found this chip was freezing by interfering signal but, it doesn't reset at all that. there is reset process "cop" inside my source code.
ラベル(2)
1,606件の閲覧回数
stephanie_m
How are you handling the NMI (Non-Maskarable Interrupt )? You can refer to this document as this is also for a cortex M0+.
Please check the chapter 2.1.3.4.1 RESET_b and NMI_b for hardware recommendations, also there are some examples, that also disable it bye SW.
I believe the NMI might be the root cause of your issue; if this does not solve your issue, let me know.
Estephania
