QN908x Power consumption per periphery
3,206 次查看
arpad_toth
In which document can I find out about the static Power consumption per periphery for QN908x?
In particular the uA usage of WDT and BOR.
the following document doesnt contain it: "Ultra low power Bluetooth 5 system-on-chip solution Rev. 1.2"
Thank you,
  • QN
3,072 次查看
stephanie_m
Sorry for the inconvenience this might cause you, but we only have for the BOR  ~150pA into the pin at VDD (3V) and ~-200pA at VSS, the WDT is a digital IP, so we typically characterize the analog ones.
Estephania
5 回复数
3,072 次查看
stephanie_m
Could you please check the QN9080 User Manual? I believe you will find some useful information in chapter  5 Power Management Unit (PMU)
Estephania
3,072 次查看
arpad_toth
It also doesn't mention current consumption of BOD/WDT. Can NXP provide this information?
Cheers,
3,072 次查看
stephanie_m
Let me check if we have the information available.
Estephania
3,072 次查看
stephanie_m
I'm still looking if we have something available, hope to have an update something soon.
Estephania
3,073 次查看
stephanie_m
Estephania
