QN9080 DAC
QN9080 DAC
1,167件の閲覧回数
Kynnans
Here is my Keil CODE to generate a DAC value based QN9080-pin PA28(Sigma-Delta).Anyway, how can i change the value of config.ana_cfg.vcm,the dac value is always 1.5V
1,134件の閲覧回数
Ricardo_Zamora
Hope you are doing well. By any chance, are you using one of our SDK examples as a base?
I would recommend checking the dac_basic example. It will help you testing the output of the dac, with different values.
Ricardo
