QN9080 BLE
QN9080 BLE
1,783 次查看
Kynnans
i designed a pcb based QN9080,and download the temperature_sersor of wireless_examples. I changed the connection interval gcConnectionIntervalMinDefault_c to 800U, the gcConnectionIntervalMaxDefault_c to1600U, but It doesn't seem to work,and This is the current consumption diagram of BLE connection after modifying the connection interval
3 回复数
1,773 次查看
KaiLi
Hello @Kynnans
Let's check where the problem may be. Before modifying, can your device work fine?
1,766 次查看
Kynnans
i found the reason, i need to use the function Gap_UpdateConnectionParameters. but there is  another RF event that occurs every 30ms , I don't know what this event is.
1,749 次查看
KaiLi
Hello @Kynnans
Can you share your code with us? Because I don't clear how do you call this API.
