QN9080 BLE scanner
QN9080 BLE scanner
2,330 次查看
arpad_toth
Is there an example for BLE observer example in "BLE Host stack QN9080DK MCUXpresso SDK 2.2.0", which scans/lists for beacons?
I only found beacon broadcaster example.
标签 (2)
2,153 次查看
mario_castaneda
Hi Arpad,
Please look at the Temperature Collector example. It connects with the temperature sensor and is using the BLE Scanner.
Also, look at the next community post. https://community.nxp.com/docs/DOC-341402
Hope it helps and let me know if you have more questions.
Mario
2,154 次查看
mario_castaneda
Hi Arpad,
Mario
