Programming multi TPMS sensor
1,961 次查看
tedwu1
I use development board of FRDM-KW019032 (MCU:MKW01Z128) to program 16 TPMS sensors at the same time.
The sensor use FXTHxx11. Do you have any code of development board of FRDM-KW019032 for programming multi TPMS sensors for ? Can you guide me how to do that?
标记 (1)
1,907 次查看
reyes
Unfortunately no, we do not have any code of development board of FRDM-KW019032 for programming multi TPMS sensors or any guideline or document about how to do it.
Sorry about that.
The only document that we have that could be useful for your case is an Application Note that discusses how to use a Kinetis KW01 as the Receiver for the FXTH870xD TPMS Sensor, it does not mention anything about how to program multiple TPMS sensors. In case you are interested, this app note is the AN5136 and can be found in the following link: https://www.nxp.com/docs/en/application-note/AN5136.pdf
Jose
