Please, support me with S-parameter data
2,046件の閲覧回数
ababij
NXP, TechSupport,
I plan to use AFT05MP075N and AFT09MS015N LDMOS Transistors in mobile application for avionic frequency range (118-137MHz), unfortunately date sheets don't offer S-parameters for this frequency range. Please help me and publish S-parameters for the 118-137MHz frequency range (simulated will be good).
Thank for the effort.
ababij
タグ(2)
3 返答(返信)
2,031件の閲覧回数
diazmarin09
Hello Ababij,
I hope all is great with you. Thank you for using the NXP communities.
You may find the S-parameter available at the web page of each device (AFT05MP075N, AFT09MS015N).
Unfortunately, the datasheet does not provide any further information regarding other frequencies.
I hope this information helps.
David
2,025件の閲覧回数
ababij
Thank You for the answer, I know the file, unfortunately the data starts from 200MHz, but I need data from 118MHz (100MHz). I call for the help further. Greetings
2,015件の閲覧回数
diazmarin09
Hello Ababij,
Thank you for using the NXP community.
Unfortunately, that is all the information that we have available. Please accept my apologies for any inconvenience.
David
