Peripheral send rejection on update connection parameter after Master accepts it and send PARAM_REQ.
mahmoud_k_elkas
Hello everybody.
I'm using QN9080 as a peripheral, I implement connection parameter request using "APP_GapcParamUpdateCmd" API after Master accepts it and sends PARAM_REQ, peripheral send rejection on PARAM_REQ to master due to Collision. I read in specs that the master who sends rejection if there is any collision happens.
I have a couple of questions.
1- Why peripheral rejects that after master accepts?
2- I can catch the error code when the Master accepts/rejects the connection parameter.
    is there any way to catch the error code if peripheral sends it?
Any help?
  • QN
stephanie_m
How are you implementing the flow of the code to start the connection? Are you using some examples as a base?
Estephania
