PWM dimming, from high duty cycle to low duty cycle(80%---50%), the human eye feels that the light will flash a few times
2,001件の閲覧回数
yuboli
My pwm dimming program is
vAHI_TimerEnable(E_AHI_TIMER_1, 2, FALSE, FALSE, TRUE);
vAHI_TimerConfigureOutputs(E_AHI_TIMER_1, TRUE, TRUE); /* Invert PWM and disable gating */
vAHI_TimerClockSelect(E_AHI_TIMER_1, FALSE, TRUE);
vAHI_TimerStartRepeat(E_AHI_TIMER_1,Level_Value,4000000/477);
When I change the Level_Value value, the duty cycle will change.But the light flash a few times
5 返答(返信)
1,796件の閲覧回数
FelipeGarcia
Hi Daniel,
Could you please tell me which board are you working on?
Also, I'd like you to explain in detail your issue so I can replicate it and give you a better support.
Felipe
1,796件の閲覧回数
yuboli
hi Felipe Garcia,
I use the JN-AN-1218-Zigbee-3-0-Light-Bulb project, compile options select DimmableLight, GpProxy, JN5169, DR1175.But the process of adjusting the duty cycle, the bulb will flash a few times;The duty cycle is correct, but I don’t know why.
1,796件の閲覧回数
FelipeGarcia
Hi Daniel,
Sorry for my late reply.
Could you please try adding a delay before StartRepeat?
Also, could you please provide the DIO pin you are using?
Felipe
1,796件の閲覧回数
yuboli
hi  Felipe Garcia
   I adjust the duty cycle process, there is a time gradual process, the time is about 3s; why does it look like a few times when the brightness is low? My minimum gradient is 1;pastedImage_1.png
1,796件の閲覧回数
FelipeGarcia
Hi Daniel,
I tested this on my side and I couldn’t see this behavior. I changed the duty cycle from around 50 to 90% and the LED didn’t blink.
From what I understand, when you change the duty cycle, the LED blinks a few times before the duty cycle is updated. The PWM is working fine but there are some flashes at the beginning of the process.
Am I correct?
Felipe
