Nfc explorer not working.
1,307 次查看
christopaul
     Im doing a project using the Explore nfc with Raspberry pi. We got the board and installed the software. It was working at first but later when we executed the basic nfc read command,  it showed waiting for tag or device, but there wad response when a tag is introduced to it.
     Later the same command resulted into an error where it showed Adapter not found. Please help us with this problem. Thank You.
0 回复数
