NCF3320 NCJ3320 data sheet differnce
lim
can i know why do you separate  NCF3320 and NCJ3320 with temperature range?
Data sheet contents of NCJ3320 cannot be found in NCF3320. Are the functions not available in NCF3320?
NCJ3320 product sheet
8.7.2.21 T4RloadHi register
8.7.2.23 T4CounterValHi register
Receiver configuration
8.17.3 RxSynchValH register
8.17.5 RxSynchMod register
fangfang
As the device you are using is under NDA and as it is used for automotive applications you will need to go with your DBM (Distributor Business Manager)  for further support on this matter as we do not have access to the information. Sorry for the inconvenience may cause.
Have a nice day.
