MKW24D512VHA5 chip security
已解决
跳至解决方案
3,430 次查看
yuhuixuan
I use MKW24D512VHA5 in my product. I want to protect the code in the chip. So I want to know the way about the chip security that the code in the flash can't be read from the chip.
Could you give me the document about this? And the source code better. Thank you very much.
I have check the "MKW2xDxxx.pdf". I write flash address 0x040C with the value 0xF0. Then the flash can't be read again. Is there any better way to security the chip?
标签 (2)
标记 (2)
1 解答
3,202 次查看
DavidS
2 回复数
3,202 次查看
yuhuixuan
Thank you
3,203 次查看
DavidS
