MKW24D512VHA5 chip security
3,435件の閲覧回数
yuhuixuan
I use MKW24D512VHA5 in my product. I want to protect the code in the chip. So I want to know the way about the chip security that the code in the flash can't be read from the chip.
Could you give me the document about this? And the source code better. Thank you very much.
I have check the "MKW2xDxxx.pdf". I write flash address 0x040C with the value 0xF0. Then the flash can't be read again. Is there any better way to security the chip?
ラベル(2)
タグ(2)
3,207件の閲覧回数
DavidS
3,207件の閲覧回数
yuhuixuan
Thank you
3,208件の閲覧回数
DavidS
