MFRC522 not switchable to UART
PaoloArtuso
I am trying to use the UART interface instead of the SPI with MFRC522.
I set the EA pin and i2c to GND, but the communication is still working in SPI, I am not able to use UART.
Pin are measured with multimeter and value are ok.
Tried a reset with dedicated pin but still working is SPI  and not UART.
Is there any suggestion?
Thank you for support
