Keyboard interrupt for infinite loop
1,881件の閲覧回数
ashkanrezaee
I want to make a keyboard interrupt during a "while" infinite loop on QN9080. If I use "GETCHAR" or "SCANF", program stop until I press something. But I want to have the loop until I press something (anything) on the keyboard to make an interrupt.
ラベル(2)
タグ(2)
1,774件の閲覧回数
stephanie_m
Are you using Bluetooth Le? Or are you testing just the board drivers?
You can check the available examples for each in the SKD, there is one for a keyboard that might help you as a guide and one for an HID device working with Bluetooth LE.
If you are just getting started with the QN9080, I would recommend you to check first the driver example and after that check the Bluetooth one.
The examples can be downloaded from the MCUXpresso dashboard  .
Estephania
