KW47 VSCode Integration
1,726件の閲覧回数
ciband
I am trying to get the KW47 bluetooth digital key anchor freeRTOS SDK sample imported and building.  When I attempt to import the example application I get this error:
Error: Failed to create freestanding example: Traceback (most recent call last):
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/commands.py", line 565, in __call__
    mod = _commands_module_from_file(self.py_file)
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/commands.py", line 718, in _commands_module_from_file
    spec.loader.exec_module(mod)
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/grmn/prj/aoem/mcuxpresso-sdk/mcuxsdk/mcuxsdk/scripts/west_commands/export_app.py", line 12, in <module>
    from export_app.cmake_parser import cmparser
  File "/grmn/prj/aoem/mcuxpresso-sdk/mcuxsdk/mcuxsdk/scripts/west_commands/export_app/cmake_parser.py", line 11, in <module>
    from jinja2 import Template
ModuleNotFoundError: No module named 'jinja2'
The above exception was the direct cause of the following exception:
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/app/main.py", line 584, in run_command
    self.run_extension(args.command, argv)
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/app/main.py", line 708, in run_extension
    self.cmd = self.extensions[name].factory()
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/commands.py", line 567, in __call__
    raise ExtensionCommandError(
west.commands.ExtensionCommandError
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
    exec(code, run_globals)
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/__main__.py", line 3, in <module>
    main()
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/app/main.py", line 1199, in main
    app.run(argv or sys.argv[1:])
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/app/main.py", line 278, in run
    self.run_command(argv, early_args)
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/app/main.py", line 628, in run_command
    self.handle_extension_command_error(ece)
  File "/home/johnsonchris/.local/lib/python3.10/site-packages/west/app/main.py", line 454, in handle_extension_command_error
    self.cmd.err(msg, fatal=True)
AttributeError: 'NoneType' object has no attribute 'err'
To my knowledge all of the dependencies are satisfied.  I attempted to install the SDK dependency manager application on Linux but this installation also fails.
1,638件の閲覧回数
ciband
Missing jinja2 package was the solution.  pip3 install jinja2
1,639件の閲覧回数
ciband
%3CLINGO-SUB%20id%3D%22lingo-sub-2265168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW47%20VSCode%20%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EKW47%20Bluetooth%20%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%20%E3%82%AD%E3%83%BC%20%E3%82%A2%E3%83%B3%E3%82%AB%E3%83%BC%20freeRTOS%20SDK%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fcommands.py%22%2C__call__%E3%81%AE%20565%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Emod%20%3D%20_commands_module_from_file(self.py_file)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fcommands.py%22%2C_commands_module_from_file%20%E3%81%AE%20718%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Espec.loader.exec_module(mod)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%3CFROZEN%20importlib._bootstrap_external%3D%22%22%3E%22%E3%80%81exec_module%E3%81%AE883%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%3CFROZEN%20importlib._bootstrap%3D%22%22%3E%22%E3%80%81241%E8%A1%8C%E7%9B%AE%E3%80%81_call_with_frames_removed%E5%86%85%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fgrmn%2Fprj%2Faoem%2Fmcuxpresso-sdk%2Fmcuxsdk%2Fmcuxsdk%2Fscripts%2Fwest_commands%2Fexport_app.py%22%2C%3CMODULE%3E%20%E3%81%AE%2012%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Eexport_app.cmake_parser%E3%81%8B%E3%82%89cmparser%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fgrmn%2Fprj%2Faoem%2Fmcuxpresso-sdk%2Fmcuxsdk%2Fmcuxsdk%2Fscripts%2Fwest_commands%2Fexport_app%2Fcmake_parser.py%22%2C%3CMODULE%3E%20%E3%81%AE%2011%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Ejinja2%E3%81%8B%E3%82%89%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3EModuleNotFoundError%3A%20'jinja2'%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FMODULE%3E%3C%2FMODULE%3E%3C%2FFROZEN%3E%3C%2FFROZEN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E4%BE%8B%E5%A4%96%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E4%BE%8B%E5%A4%96%E3%81%AE%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fapp%2Fmain.py%22%2C584%E8%A1%8C%E7%9B%AE%E3%80%81run_command%3CBR%20%2F%3E%20self.run_extension(args.command%2C%20argv)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fhome%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fapp%2Fmain.py%22%2Crun_extension%E3%81%AE708%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Eself.cmd%20%3D%20self.extensions%5B%E5%90%8D%E5%89%8D%5D.factory()%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fhome%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fcommands.py%22%2C__call__%E3%81%AE%20567%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3EExtensionCommandError%20%E3%82%92%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99(%3CBR%20%2F%3E%20west.commands.ExtensionCommandError%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E4%BE%8B%E5%A4%96%E3%81%AE%E5%87%A6%E7%90%86%E4%B8%AD%E3%81%AB%E3%80%81%E5%88%A5%E3%81%AE%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fusr%2Flib%2Fpython3.10%2Frunpy.py%22%2C_run_module_as_main%20%E3%81%AE%20196%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E_run_code(code%2C%20main_globals%2C%20None%2C%20%E3%82%92%E8%BF%94%E3%81%99)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fusr%2Flib%2Fpython3.10%2Frunpy.py%22%2C_run_code%E3%81%AE86%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3Eexec(%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81run_globals)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2F__main__.py%22%2C%3CMODULE%3E%20%E3%81%AE%203%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E%E4%B8%BB%E8%A6%81%EF%BC%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fapp%2Fmain.py%22%2C1199%E8%A1%8C%E7%9B%AE%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%3CBR%20%2F%3Eapp.run(argv%E3%81%BE%E3%81%9F%E3%81%AFsys.argv%5B1%3A%5D)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fapp%2Fmain.py%22%2C278%E8%A1%8C%E7%9B%AE%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Eself.run_command(argv%2Cearly_args)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fapp%2Fmain.py%22%2C628%E8%A1%8C%E7%9B%AE%E3%80%81run_command%3CBR%20%2F%3E%20self.handle_extension_command_error(ece)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fjohnsonchris%2F.local%2Flib%2Fpython3.10%2Fsite-packages%2Fwest%2Fapp%2Fmain.py%22%2C454%E8%A1%8C%E7%9B%AE%E3%80%81handle_extension_command_error%3CBR%20%2F%3E%20self.cmd.err(%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%2C%E8%87%B4%E5%91%BD%E7%9A%84%3DTrue)%3CBR%20%2F%3E%20AttributeError%3A%20'NoneType'%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E5%B1%9E%E6%80%A7%20'err'%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FMODULE%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AF%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linux%20%E3%81%AB%20SDK%20%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%82%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW47%20VSCode%20Integration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81jinja2%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82pip3%20jinja2%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
