KW45 get rssi
KW45 get rssi
2,498件の閲覧回数
wjw2026
1、Using the api(Gap_ReadRssi) to get the rssi, we found that many results are 0x7f,the following is the log picture
2、The rssi is obtained by the event(gNotifConnEventOver_c), and it turns out that there are many 0xff,the following is the log picture
3 返答(返信)
2,473件の閲覧回数
Ricardo_Zamora
Hope you are doing well. What SDK version are you using? Could you please tell us what SDK example are you using as a base?
What modifications did you made? Are you using our KW45B41Z Evaluation Kit?
Ricardo
2,461件の閲覧回数
wjw2026
Hi:
SDK version 2.12.6
SDK example:w_uart
#define Gap_ReadRssi(deviceId) Gap_ReadRadioPowerLevel(gRssi_c, (deviceId))
What I want to ask is to get rssi through the api(Gap_ReadRssi), but sometimes I get rssi 0x7f
2,452件の閲覧回数
Ricardo_Zamora
What modifications did you made to the SKD example?
Could you please check if this behavior is happening with ble shell example?
Ricardo
