KW45: Intermittent Wire ACK Fault During Programming/Debugging and Flash Erase Failure
67 次查看
Prashanth1
Hi Team,
I am currently working with a KW45-based custom board and facing an intermittent issue during programming and debugging the firmware.
I have tested the board with both a SEGGER J-Link and an NXP MCU-Link debug probe, and the issue occurs with both probes.
The custom board has the same boot configuration as the KW45 EVK, and the JTAG/SWD connections have also been checked and appear to be correct.
However, I am seeing the following behaviour:
When I try to dump or program a known-working application:
  • Sometimes the application is programmed successfully, but after programming or starting a debug session, the device eventually jumps to a fault address.
  • The debugger then halts at that location.
  • During some programming or dumping attempts, I receive a Wire ACK fault.
  • At other times, MCUXpresso reports:
    Error while executing the MI command
  • I also tried to erase the flash from MCUXpresso, but the flash erase operation itself does not complete successfully.
Checks already performed
  • JTAG/SWD connections have been checked and appear to be correct.
  • The issue was tested with both a SEGGER J-Link and an NXP MCU-Link debug probe.
    Boot configuration has been compared with the KW45 EVK.
  • I am using a known-working application for testing.
    The issue is intermittent: programming sometimes succeeds, but at other times a Wire ACK fault or MI command error occurs.
  • Flash erase has also been attempted, but it does not complete successfully.
My questions
  • What could cause the KW45 to: Intermittently report a Wire ACK fault while dumping or programming code?
  • Report Error while executing the MI command?
  • Jump or halt at an unexpected or invalid memory address after programming?
  • Fail even when attempting a full flash erase?
Since the issue includes intermittent Wire ACK faults and failure during flash erase, I suspect this may be related to the debug interface, SWD/JTAG signal integrity, power-supply stability, reset sequence, flash controller state, device security/configuration, boot configuration, or another hardware-level issue rather than the application itself.
  1. Could you please suggest the recommended procedure to:
  2. Recover or erase the KW45 device.
  3. Verify that the debug interface is functioning correctly.
  4. Check whether the device is secured or in a state that prevents normal programming.
  5. Determine whether the Wire ACK fault is caused by the target hardware, debug probe, power/reset behavior, or SWD/JTAG signal integrity.
I can provide the following information if required:
  • MCUXpresso IDE version: 25.6.1
  • Debug probes tested: SEGGER J-Link and NXP MCU-Link
  • Complete error log, including the Wire ACK fault details
  • Debug console output
  • Schematic of the JTAG/SWD and boot connections
  • SWD/JTAG clock frequency
  • Power-supply and reset configuration
  • Memory/register information from the failed state
Any guidance on the recommended troubleshooting steps would be greatly appreciated.
Thanks in advance.
标记 (1)
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2411879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW45%EF%BC%9A%E7%BC%96%E7%A8%8B%2F%E8%B0%83%E8%AF%95%E6%9C%9F%E9%97%B4%E9%97%B4%E6%AD%87%E6%80%A7%E7%BA%BF%E8%B7%AF%E7%A1%AE%E8%AE%A4%E6%95%85%E9%9A%9C%E5%92%8C%E9%97%AA%E5%AD%98%E6%93%A6%E9%99%A4%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20KW45%20%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%EF%BC%8C%E5%9C%A8%E5%9B%BA%E4%BB%B6%E7%BC%96%E7%A8%8B%E5%92%8C%E8%B0%83%E8%AF%95%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E4%BA%86%E9%97%B4%E6%AD%87%E6%80%A7%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%86%E5%88%AB%E4%BD%BF%E7%94%A8%20SEGGER%20J-Link%20%E5%92%8C%20NXP%20MCU-Link%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E6%B5%8B%E8%AF%95%E4%BA%86%E8%AF%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%8C%E4%B8%A4%E7%A7%8D%E6%8E%A2%E9%92%88%E9%83%BD%E5%87%BA%E7%8E%B0%E4%BA%86%E8%AF%A5%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%9A%E5%88%B6%E6%9D%BF%E7%9A%84%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E4%B8%8E%20KW45%20EVK%20%E7%9B%B8%E5%90%8C%EF%BC%8CJTAG%2FSWD%20%E8%BF%9E%E6%8E%A5%E4%B9%9F%E5%B7%B2%E6%A3%80%E6%9F%A5%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%83%85%E5%86%B5%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BD%AC%E5%82%A8%E6%88%96%E7%BC%96%E7%A8%8B%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%9C%89%E6%97%B6%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%BC%96%E7%A8%8B%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E5%9C%A8%E7%BC%96%E7%A8%8B%E6%88%96%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E5%90%8E%EF%BC%8C%E8%AE%BE%E5%A4%87%E6%9C%80%E7%BB%88%E4%BC%9A%E8%B7%B3%E8%BD%AC%E5%88%B0%E6%95%85%E9%9A%9C%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%B0%83%E8%AF%95%E5%99%A8%E9%9A%8F%E5%90%8E%E5%9C%A8%E8%AF%A5%E4%BD%8D%E7%BD%AE%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%9C%A8%E6%9F%90%E4%BA%9B%E7%BC%96%E7%A8%8B%E6%88%96%E8%BD%AC%E5%82%A8%E5%B0%9D%E8%AF%95%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%20Wire%20ACK%20%E6%95%85%E9%9A%9C%E3%80%82%3C%2FLI%3E%3CLI%3EMCUXpresso%20%E5%9C%A8%E5%85%B6%E4%BB%96%E6%97%B6%E5%80%99%E6%8A%A5%E9%81%93%EF%BC%9A%3CBR%20%2F%3E%E6%89%A7%E8%A1%8C%20MI%20%E5%91%BD%E4%BB%A4%E6%97%B6%E5%87%BA%E9%94%99%3C%2FLI%3E%3CLI%3E%E6%88%91%E8%BF%98%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E9%97%AA%E5%AD%98%E6%93%A6%E9%99%A4%E6%93%8D%E4%BD%9C%E6%9C%AC%E8%BA%AB%E5%B9%B6%E6%9C%AA%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%B7%B2%E6%89%A7%E8%A1%8C%E7%9A%84%E6%A3%80%E6%9F%A5%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%B7%B2%E6%A3%80%E6%9F%A5%20JTAG%2FSWD%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E8%BF%9E%E6%8E%A5%E4%BC%BC%E4%B9%8E%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20SEGGER%20J-Link%20%E5%92%8C%20NXP%20MCU-Link%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E6%B5%8B%E8%AF%95%E4%BA%86%E8%AF%A5%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E5%B7%B2%E5%B0%86%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E4%B8%8E%20KW45%20EVK%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%AF%94%E8%BE%83%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3CBR%20%2F%3E%E8%AF%A5%E9%97%AE%E9%A2%98%E6%98%AF%E9%97%B4%E6%AD%87%E6%80%A7%E7%9A%84%EF%BC%9A%E6%9C%89%E6%97%B6%E7%BC%96%E7%A8%8B%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E6%9C%89%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%20Wire%20ACK%20%E6%95%85%E9%9A%9C%E6%88%96%20MI%20%E5%91%BD%E4%BB%A4%E9%94%99%E8%AF%AF%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E9%97%AA%E5%AD%98%E6%93%A6%E9%99%A4%EF%BC%8C%E4%BD%86%E6%9C%AA%E8%83%BD%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E4%BC%9A%E5%AF%BC%E8%87%B4%20KW45%20%E5%9C%A8%E8%BD%AC%E5%82%A8%E6%88%96%E7%BC%96%E7%A8%8B%E4%BB%A3%E7%A0%81%E6%97%B6%E9%97%B4%E6%AD%87%E6%80%A7%E5%9C%B0%E6%8A%A5%E5%91%8A%20Wire%20ACK%20%E6%95%85%E9%9A%9C%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%89%A7%E8%A1%8C%20MI%20%E5%91%BD%E4%BB%A4%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E7%BC%96%E7%A8%8B%E5%90%8E%E8%B7%B3%E8%BD%AC%E5%88%B0%E6%88%96%E5%81%9C%E6%AD%A2%E5%9C%A8%E6%84%8F%E5%A4%96%E6%88%96%E6%97%A0%E6%95%88%E7%9A%84%E5%86%85%E5%AD%98%E5%9C%B0%E5%9D%80%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%8D%B3%E4%BD%BF%E5%B0%9D%E8%AF%95%E5%AE%8C%E5%85%A8%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%E4%B9%9F%E5%A4%B1%E8%B4%A5%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%94%B1%E4%BA%8E%E8%AF%A5%E9%97%AE%E9%A2%98%E5%8C%85%E6%8B%AC%E9%97%B4%E6%AD%87%E6%80%A7%20Wire%20ACK%20%E6%95%85%E9%9A%9C%E5%92%8C%E9%97%AA%E5%AD%98%E6%93%A6%E9%99%A4%E6%9C%9F%E9%97%B4%E7%9A%84%E6%95%85%E9%9A%9C%EF%BC%8C%E6%88%91%E6%80%80%E7%96%91%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E3%80%81SWD%2FJTAG%20%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E3%80%81%E7%94%B5%E6%BA%90%E7%A8%B3%E5%AE%9A%E6%80%A7%E3%80%81RESET%20%E5%BA%8F%E5%88%97%E3%80%81%E9%97%AA%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E7%8A%B6%E6%80%81%E3%80%81%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%2F%E9%85%8D%E7%BD%AE%E3%80%81%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E6%88%96%E5%85%B6%E4%BB%96%E7%A1%AC%E4%BB%B6%E7%BA%A7%E9%97%AE%E9%A2%98%E6%9C%89%E5%85%B3%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%9C%AC%E8%BA%AB%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E4%BB%A5%E4%B8%8B%E6%96%B9%E9%9D%A2%E7%9A%84%E6%8E%A8%E8%8D%90%E6%93%8D%E4%BD%9C%E6%B5%81%E7%A8%8B%EF%BC%9A%3C%2FLI%3E%3CLI%3E%E6%81%A2%E5%A4%8D%E6%88%96%E6%93%A6%E9%99%A4%20KW45%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%A1%AE%E8%AE%A4%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E5%8A%9F%E8%83%BD%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%A3%80%E6%9F%A5%E8%AE%BE%E5%A4%87%E6%98%AF%E5%90%A6%E5%B7%B2%E9%94%81%E5%AE%9A%E6%88%96%E5%A4%84%E4%BA%8E%E9%98%BB%E6%AD%A2%E6%AD%A3%E5%B8%B8%E7%BC%96%E7%A8%8B%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%A1%AE%E5%AE%9A%20Wire%20ACK%20%E6%95%85%E9%9A%9C%E6%98%AF%E7%94%B1%E7%9B%AE%E6%A0%87%E7%A1%AC%E4%BB%B6%E3%80%81%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E3%80%81%E7%94%B5%E6%BA%90%2F%E5%A4%8D%E4%BD%8D%E8%A1%8C%E4%B8%BA%E8%BF%98%E6%98%AF%20SWD%2FJTAG%20%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E5%BC%95%E8%B5%B7%E7%9A%84%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%A6%82%E6%9C%89%E9%9C%80%E8%A6%81%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3EMCUXpresso%20IDE%20%E7%89%88%E6%9C%AC%EF%BC%9A25.6.1%3C%2FLI%3E%3CLI%3E%E6%B5%8B%E8%AF%95%E7%9A%84%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%EF%BC%9ASEGGER%20J-Link%20%E5%92%8C%20NXP%20MCU-Link%3C%2FLI%3E%3CLI%3E%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%8C%E5%8C%85%E6%8B%AC%20Wire%20ACK%20%E6%95%85%E9%9A%9C%E8%AF%A6%E6%83%85%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BE%93%E5%87%BA%3C%2FLI%3E%3CLI%3EJTAG%2FSWD%20%E5%92%8C%E5%90%AF%E5%8A%A8%E8%BF%9E%E6%8E%A5%E7%A4%BA%E6%84%8F%E5%9B%BE%3C%2FLI%3E%3CLI%3ESWD%2FJTAG%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%3C%2FLI%3E%3CLI%3E%E7%94%B5%E6%BA%90%E5%92%8C%20RESET%20%E9%85%8D%E7%BD%AE%3C%2FLI%3E%3CLI%3E%E6%9D%A5%E8%87%AA%E6%95%85%E9%9A%9C%E7%8A%B6%E6%80%81%E7%9A%84%E5%86%85%E5%AD%98%2F%E5%AF%84%E5%AD%98%E5%99%A8%E4%BF%A1%E6%81%AF%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%AD%A5%E9%AA%A4%E6%96%B9%E9%9D%A2%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
