KW45 First Time Programming
15,217 次查看
cnew01
I am trying to program a custom KW45-based PCB for the first time. I tried using MCUXpresso. The J-Link could upload my program over SWD but when I tried entering debug mode the board halts at address 0x14816fdc. Further research has shown that the NBU for the Bluetooth coprocessor needs to be uploaded. I've tried AN13838, but my board cannot be discovered over UART. I've been looking into AN14003, but it's information is out of date with regards to the current SPSDK. What do I do?
12,649 次查看
cnew01
Closing this thread. There was a design error in the custom hardware that had a permanent pull up on the boot_config pin. Once removed, the issue was resolved and the NBU could be programmed as specified in AN14003.
24 回复数
3,675 次查看
cnew01
The blhost is not detecting my UART to USB converter that i have connected to the board. Im using a different converter on COM8 but I am having the same issue I was having with the converter on COM15.
4,678 次查看
cnew01
I've tried following an14003 section 5 (omitting section 3) using the evk sb3. The one modification I made was setting
loader_info.partition_desc = PLATFORM_OtaGetOtaInternalPartitionConfig();
I'm still encountering the same error once merging the generated binary and the SB3. What would you reccomend I look into?
4,625 次查看
luis_maravilla
PLATFORM_OtaGetOtaInternalPartitionConfig  returns internal partition configuration structure, what you could try is make the initialization manually, to ensure the internal flash is selected and the values start at 0.
Let me know if that worked for you.
OtaPartition_t Test_ota_partition =
    /*start_offset*/ 0,\
    /*size*/         0,\
    /*sector_size*/  0,\
    /*page_size*/    0,\
    /*internal_flash*/ true,\
    /*spi_baudrate*/ 0,\
loader_info.partition_desc = &Test_ota_partition;
3,426 次查看
cnew01
I will clarify that LPUART0 TX and RX pins are accessible on this custom board through a header.
%3CLINGO-SUB%20id%3D%22lingo-sub-2162913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW45%20%E9%A6%96%E6%AC%A1%E7%BC%96%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%B0%9D%E8%AF%95%E5%AF%B9%E5%9F%BA%E4%BA%8E%20KW45%20%E7%9A%84%E5%AE%9A%E5%88%B6%20PCB%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%E6%88%91%E8%AF%95%E7%9D%80%E4%BD%BF%E7%94%A8%20MCUXpresso%E3%80%82J-Link%20%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20SWD%20%E4%B8%8A%E4%BC%A0%E6%88%91%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%8C%E6%9D%BF%E5%9C%A8%E5%9C%B0%E5%9D%80%200x14816fdc%20%E5%A4%84%E5%81%9C%E6%9C%BA%E3%80%82%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%A0%94%E7%A9%B6%E8%A1%A8%E6%98%8E%EF%BC%8C%E9%9C%80%E8%A6%81%E4%B8%8A%E4%BC%A0%E8%93%9D%E7%89%99%E5%8D%8F%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%20NBU%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%20AN13838%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20UART%20%E5%8F%91%E7%8E%B0%E6%88%91%E7%9A%84%E6%9D%BF%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E7%A0%94%E7%A9%B6%20AN14003%EF%BC%8C%E4%BD%86%E5%B0%B1%E7%9B%AE%E5%89%8D%E7%9A%84%20SPSDK%20%E8%80%8C%E8%A8%80%EF%BC%8C%E5%AE%83%E7%9A%84%E4%BF%A1%E6%81%AF%E5%B7%B2%E7%BB%8F%E8%BF%87%E6%97%B6%E3%80%82%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E9%98%85%E8%AF%BB%E8%BF%99%E4%B8%AA%E8%AF%9D%E9%A2%98%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E4%BD%A0%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%20AN14003%20%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%9D%A5%E4%BD%BF%E7%94%A8%20SWD%20%E5%AF%B9%20KW45%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E5%B7%B2%E7%BB%8F%E6%9C%89%E7%82%B9%E5%B9%B4%E5%A4%B4%E4%BA%86%EF%BC%8C%3CSTRONG%3E%E4%BD%A0%E6%88%90%E5%8A%9F%E4%BA%86%E5%90%97%EF%BC%9F%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E6%83%B3%E5%9C%A8%E8%BF%99%E9%87%8C%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%9C%A8%E7%94%9F%E6%88%90%E5%AF%86%E9%92%A5%E5%92%8C%E5%88%9B%E5%BB%BA%E5%AE%89%E5%85%A8%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%20jupyter%20%E9%83%A8%E5%88%86%E6%96%B9%E9%9D%A2%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%E5%AF%B9%E4%BA%8E%E8%BF%99%E9%83%A8%E5%88%86%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%90%8C%E4%B8%80%E4%B8%BB%E9%A2%98%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%20SPSDK%20CLI%20%E5%B7%A5%E5%85%B7%EF%BC%88%E6%88%91%E6%8C%87%E7%9A%84%E6%98%AF%E7%94%9F%E6%88%90%E5%AF%86%E9%92%A5%E5%92%8C%20sb3%20%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%90%88%E5%B9%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%97%B6%E4%BC%9A%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%3CSTRONG%3Eotap_client_freertos%3C%2FSTRONG%3Esdk%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%B9%B6%E5%81%9A%E4%BA%86%E4%B8%8A%E8%BF%B0%E4%BF%AE%E6%94%B9%E3%80%82%E5%B9%B6%E7%94%9F%E6%88%90%E4%BA%86%20bin%20%E6%96%87%E4%BB%B6%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E7%94%A8%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E7%BC%96%E8%BE%91%E5%99%A8%E6%89%93%E5%BC%80%E4%BA%86%3CSTRONG%3Eotap_client_freertos.bin%26amp%3B%20kw45b41_nbu_ble_xp_hosted.sb3%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E5%B0%86%20sb3%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%86%85%E5%AE%B9%E5%A4%8D%E5%88%B6%E5%88%B0%E4%BA%86%3CSTRONG%3Eotap_client_freertos.bin%3C%2FSTRONG%3E%E7%9A%84%3CSTRONG%3E0x7A000%3C%2FSTRONG%3E%E5%9C%B0%E5%9D%80%E4%B8%8A%E3%80%82%3CSTRONG%3E%20%3C%2FSTRONG%3E%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%E3%80%82%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%86%E5%90%88%E5%B9%B6%E5%90%8E%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%8A%A0%E8%BD%BD%E5%88%B0%20SEGGER%20J-Flash%20%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%B0%86%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%88%B7%E6%96%B0%E5%88%B0%20KW45%20%E4%B8%AD%E3%80%82%E4%BD%86%E6%93%8D%E4%BD%9C%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E7%94%9A%E8%87%B3%E8%BF%9E%E9%97%AA%E7%83%81%E7%A4%BA%E4%BE%8B%E4%B9%9F%E6%97%A0%E6%B3%95%E7%BC%96%E7%A8%8B%E3%80%82%E4%B8%BA%E4%BA%86%E4%BB%8E%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%AD%E6%81%A2%E5%A4%8D%E8%BF%87%E6%9D%A5%EF%BC%8C%E6%88%91%E4%B8%8D%E5%BE%97%E4%B8%8D%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%E5%B9%B6%E6%93%A6%E9%99%A4%E6%95%B4%E4%B8%AA%E8%8A%AF%E7%89%87%EF%BC%88%E5%8D%B3%E4%BD%BF%E6%98%AF%E6%93%A6%E9%99%A4%E8%8A%AF%E7%89%87%EF%BC%8C%E6%88%91%E4%B9%9F%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20SWD%20%E8%AE%BF%E9%97%AE%E8%8A%AF%E7%89%87%EF%BC%89%E3%80%82%20%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%90%88%E5%B9%B6%E5%90%8E%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%88%B7%E6%96%B0%E5%A4%B1%E8%B4%A5%E6%97%B6%E6%88%91%E6%94%B6%E5%88%B0%E7%9A%84%3CSTRONG%3E%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E****************************************************************************************%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%E7%BC%96%E7%A8%8B%E5%92%8C%E9%AA%8C%E8%AF%81%E7%9B%AE%E6%A0%87%EF%BC%881040384%20%E5%AD%97%E8%8A%82%EF%BC%8C1%20%E4%B8%AA%E8%8C%83%E5%9B%B4%EF%BC%89...%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E8%BF%9E%E6%8E%A5%20...%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%8E%A2%E5%A4%B4%2F%E7%BC%96%E7%A8%8B%E5%99%A8%E8%AE%BE%E5%A4%87%200%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E6%8E%A2%E5%A4%B4%2F%E7%BC%96%E7%A8%8B%E5%99%A8%E5%9B%BA%E4%BB%B6%EF%BC%9AJ-Link%20V9%20%E5%B7%B2%E7%BC%96%E8%AF%91%202022%20%E5%B9%B4%2012%20%E6%9C%88%2013%20%E6%97%A5%2011%3A14%3A50%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E6%8E%A2%E5%A4%B4%2F%E7%BC%96%E7%A8%8B%E5%99%A8%E7%BC%96%E5%8F%B7%EF%BC%9A69730348%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%E8%AE%BE%E5%A4%87%20%22%20KW45B41Z83%20%22%20%E5%B7%B2%E9%80%89%E4%B8%AD%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%E9%80%9F%E5%BA%A6%EF%BC%9A%204000%20kHz%EF%BC%88%E5%9B%BA%E5%AE%9A%E5%80%BC%EF%BC%89%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E7%9B%AE%E6%A0%87%E7%94%B5%E5%8E%8B%20%3D%203.290V%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E9%85%8D%E7%BD%AE%E7%9B%AE%E6%A0%87%E8%AE%BE%E7%BD%AE()%20%E5%90%AF%E5%8A%A8%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20ConfigTargetSettings()%20%E7%BB%93%E6%9D%9F%20-%20%E5%8D%A0%E7%94%A8%20499us%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20InitTarget()%20%E5%90%AF%E5%8A%A8%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E9%80%89%E6%8B%A9%E4%BA%86%E7%A4%BE%E7%BD%B2%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20ROM%20%E8%BF%9B%E5%85%A5%20ISP%20%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%BE%AA%E7%8E%AF%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20InitTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%20117ms%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E5%8F%91%E7%8E%B0%20SW-DP%EF%BC%8CID%20%E4%B8%BA%200x6BA02477%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E6%A3%80%E6%B5%8B%E5%88%B0%20DPv0%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20CoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E8%B7%B3%E8%BF%87%20AP%20%E5%9C%B0%E5%9B%BE%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20AP%5B0%5D%EF%BC%9AAHB-AP%EF%BC%88IDR%EF%BC%9A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%EF%BC%8CADR%EF%BC%9A%200x00000000%EF%BC%89%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E9%81%8D%E5%8E%86%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20AP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%20ROMBASE%20%E8%AF%BB%E5%8F%96%E3%80%82%E7%94%A8%E6%88%B7%E6%89%8B%E5%8A%A8%E8%AE%BE%E7%BD%AE%E7%9A%84%20CoreBaseAddr%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20AP%5B0%5D%EF%BC%9A%E6%89%BE%E5%88%B0%E6%A0%B8%E5%BF%83%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x410FD214%E3%80%82%E5%AE%9E%E7%8E%B0%E8%80%85%E4%BB%A3%E7%A0%81%EF%BC%9A0x41%20(ARM)%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E5%8A%9F%E8%83%BD%E8%AE%BE%E7%BD%AE%EF%BC%9A%E4%B8%BB%E7%BA%BF%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E7%BC%93%E5%AD%98%EF%BC%9A%E6%97%A0%E7%BC%93%E5%AD%98%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E5%8F%91%E7%8E%B0%20Cortex-M33%20r0p4%EF%BC%8CLittle%20endian%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-Cortex-M%EF%BC%88ARMv8-M%20%E5%8F%8A%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%EF%BC%89%EF%BC%9A%E8%BF%9E%E6%8E%A5%E7%9A%84%20J-Link%EF%BC%88S%2FN%2069730348%EF%BC%89%E4%BD%BF%E7%94%A8%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E5%A4%84%E7%90%86%20I%2F%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E7%9A%84%E6%97%A7%E5%9B%BA%E4%BB%B6%E6%A8%A1%E5%9D%97%E3%80%82%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%EF%BC%8C%E5%88%99%E6%97%A0%E6%B3%95%E4%BF%9D%E8%AF%81%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%B0%83%E8%AF%95%E5%8A%9F%E8%83%BD%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20FPUnit%3A%208%20%E4%B8%AA%E4%BB%A3%E7%A0%81%20(BP)%20%E6%8F%92%E6%A7%BD%E5%92%8C%200%20%E4%B8%AA%E5%AD%97%E9%9D%A2%E6%8F%92%E6%A7%BD%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%89%A9%E5%B1%95%EF%BC%9A%E5%B7%B2%E5%AE%9E%E6%96%BD%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E5%AE%89%E5%85%A8%E8%B0%83%E8%AF%95%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E8%B7%B3%E8%BF%87%20ROM%20%E8%A1%A8%E6%89%AB%E6%8F%8F%E3%80%82%E7%94%A8%E6%88%B7%E6%89%8B%E5%8A%A8%E8%AE%BE%E7%BD%AE%E7%9A%84%20CoreBaseAddr%EF%BC%9A0x80030000%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20SetupTarget()%20%E5%90%AF%E5%8A%A8%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20SetupTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%207.11ms%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E6%89%A7%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%BA%8F%E5%88%97%20...%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%20RESET%20(0%2C%200%20ms)%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20%20%20-%20ResetTarget()%20%E5%90%AF%E5%8A%A8%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20%20%20-%20%E6%9C%AA%E7%BC%96%E5%85%A5%E6%9C%89%E6%95%88%E7%94%B3%E8%AF%B7%E7%A8%8B%E5%BA%8F%E3%80%82%E8%B7%B3%E8%BF%87%20RESET%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20%20%20-%20ResetTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%201.18ms%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%E5%B7%B2%E6%89%A7%E8%A1%8C%E8%AE%BE%E5%A4%87%E7%89%B9%E5%AE%9A%E7%9A%84RESET%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20%20-%20%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%90%E5%8A%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%E9%80%9F%E5%BA%A6%EF%BC%9A%204000%20kHz%EF%BC%88%E5%9B%BA%E5%AE%9A%E5%80%BC%EF%BC%89%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%E6%89%BE%E5%88%B0%E4%BA%86%201%20%E4%B8%AA%20JTAG%20%E8%AE%BE%E5%A4%87%E3%80%82%E6%A0%B8%E5%BF%83%20ID%EF%BC%9A0x6BA02477%EF%BC%88%E6%97%A0%EF%BC%89%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%20-%20%E8%BF%9E%E6%8E%A5%E6%88%90%E5%8A%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E6%A3%80%E6%9F%A5%E6%89%80%E9%80%89%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E7%AC%A6%E5%90%88%E6%89%80%E9%80%89%E9%97%AA%E5%AD%98%E6%89%87%E5%8C%BA%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E5%BC%80%E5%A7%8B%E5%87%86%E5%A4%87%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%87%86%E5%A4%87%E7%BB%93%E6%9D%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E5%BC%80%E5%A7%8B%E7%A1%AE%E5%AE%9A%E9%97%AA%E5%AD%98%E7%BC%93%E5%AD%98%E4%B8%AD%E7%9A%84%E8%84%8F%E5%8C%BA%E5%9F%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E7%BB%93%E6%9D%9F%E7%A1%AE%E5%AE%9A%E8%84%8F%E6%B1%A1%E5%8C%BA%E5%9F%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E6%97%A0%E6%B3%95%E6%B5%8B%E9%87%8F%20CPU%20%E9%80%9F%E5%BA%A6%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E5%BC%80%E5%A7%8B%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%3CFONT%20color%3D%22%23008000%22%3E%20-%20%E7%BC%96%E7%A8%8B%E8%8C%83%E5%9B%B4%200x00000000%20-%200x00007FFF%20(%204%20%E4%B8%AA%E6%89%87%E5%8C%BA%EF%BC%8C32%20KB)%3C%2FFONT%3E%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E7%BB%93%E6%9D%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E9%94%99%E8%AF%AF%EF%BC%9A%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E5%BC%80%E5%A7%8B%E6%81%A2%E5%A4%8D%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%20%3CFONT%20color%3D%22%23FF0000%22%3E-%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%81%A2%E5%A4%8D%E7%9B%AE%E6%A0%87%E5%A4%B1%E8%B4%A5%E3%80%82RAMCode%20%E4%BB%8E%E6%9C%AA%E5%81%9C%E6%AD%A2%3C%2FFONT%3E%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E6%81%A2%E5%A4%8D%E7%BB%93%E6%9D%9F%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E9%94%99%E8%AF%AF%EF%BC%9A%E7%BC%96%E7%A8%8B%E5%92%8C%E9%AA%8C%E8%AF%81%E7%9B%AE%E6%A0%87%E5%A4%B1%E8%B4%A5%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E8%BF%87%E4%BD%8E%E6%88%96%E8%BF%87%E9%AB%98%EF%BC%8C%E7%9B%AE%E6%A0%87%E6%96%AD%E5%BC%80%EF%BC%81VTarget%20%3D%200.000V%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E%E6%96%AD%E5%BC%80...%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CEM%3E-%20%E6%96%AD%E5%BC%80%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E**********************************************************************************************%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E6%88%91%E4%BB%AC%E8%AF%95%E5%9B%BE%E7%BC%96%E7%A8%8B%E7%9A%84%E5%8C%BA%E5%9F%9F%E4%BC%BC%E4%B9%8E%E6%98%AF%3C%2FFONT%3E%20%3CSTRONG%3E%3CFONT%20color%3D%22%23008000%22%3E0x00000000%20-%200x00007FFF%3C%2FFONT%3E%3C%2FSTRONG%3E%3CFONT%20color%3D%22%23008000%22%3E%3CFONT%20color%3D%22%23000000%22%3E%26amp%3B%20%E6%A0%B9%E6%8D%AE%E6%96%87%E4%BB%B6%EF%BC%8CNBU%20%E5%9B%BA%E4%BB%B6%E8%A2%AB%E5%A4%8D%E5%88%B6%E5%88%B0%3C%2FFONT%3E%3C%2FFONT%3E%3CSTRONG%3E%3CFONT%20color%3D%22%23008000%22%3E0x7A000%3C%2FFONT%3E%3C%2FSTRONG%3E%3CFONT%20color%3D%22%23000000%22%3E%E8%B6%85%E5%87%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E5%A6%82%E6%9E%9C%E6%88%91%E8%AF%B4%E9%94%99%E4%BA%86%EF%BC%8C%E8%AF%B7%E6%8C%87%E6%AD%A3%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%AE%9A%E4%B9%89%E5%B0%86%E8%93%9D%E7%89%99%E5%9B%BA%E4%BB%B6%E4%B8%8A%E4%BC%A0%E5%88%B0%20KW45%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EOtaPartition_t%20Test_ota_partition%20%3D%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*start_offset*%2F%200%2C%5C%3CBR%20%2F%3E%2F*size*%2F%200%2C%5C%3CBR%20%2F%3E%2F*sector_size*%2F%200%2C%5C%3CBR%20%2F%3E%2F*page_size*%2F%200%2C%5C%3CBR%20%2F%3E%2F*internal_flash*%2F%20true%2C%5C%3CBR%20%2F%3E%2F*spi_baudrate*%2F%200%2C%5C%3CBR%20%2F%3E%7D%EF%BC%9B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E9%87%8C%E6%8F%90%E5%88%B0%E7%9A%84%E5%90%8C%E6%A0%B7%E9%97%AE%E9%A2%98...%3C%2FP%3E%3CP%3E%22%20%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%AE%9E%E7%8E%B0%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%8C%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%AF%86%E9%92%A5%E6%9D%A5%E9%AA%8C%E8%AF%81%E8%BF%99%E4%B8%AA%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%E5%9C%A8%20an14003%20%E4%B8%AD%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%3EOTAP%20%E7%A4%BA%E4%BE%8B%E6%88%96%E6%8F%90%E4%BE%9B%E7%9A%84%E5%85%B6%E4%BD%99%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%B2%A1%E6%9C%89%E5%AE%9A%E4%B9%89%E7%AC%AC%2013%20%E9%A1%B5%E4%B8%8A%E7%9A%84%20test_OTA_Partition%3C%2FSPAN%3E%E3%80%82%22%3CBR%20%2F%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E8%AF%A5%E5%8F%98%E9%87%8F%E7%9A%84%E6%A0%B7%E6%9C%AC%E6%95%B0%E6%8D%AE%EF%BC%9F%E5%9C%A8%E6%9F%A5%E7%9C%8B%E5%86%85%E9%83%A8%E5%AD%98%E5%82%A8%E5%99%A8%E6%97%B6%EF%BC%8C%E6%88%91%E6%84%9F%E5%88%B0%E5%BE%88%E5%9B%B0%E6%83%91%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%AA%E5%8F%98%E9%87%8F%E7%9A%84%E6%A0%B7%E6%9C%AC%EF%BC%88%E6%B5%8B%E8%AF%95%EF%BC%89%E5%80%BC%EF%BC%8C%E4%BC%9A%E6%9B%B4%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%88%91%E6%9B%B4%E5%A5%BD%E5%9C%B0%E7%90%86%E8%A7%A3%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%B3%E9%97%AD%E6%AD%A4%E4%B8%BB%E9%A2%98%E3%80%82%E5%AE%9A%E5%88%B6%E7%A1%AC%E4%BB%B6%E4%B8%AD%E5%AD%98%E5%9C%A8%E4%B8%80%E4%B8%AA%E8%AE%BE%E8%AE%A1%E9%94%99%E8%AF%AF%EF%BC%8C%E5%AF%BC%E8%87%B4%20boot_config%20%E5%BC%95%E8%84%9A%E6%B0%B8%E4%B9%85%E4%B8%8A%E6%8B%89%E3%80%82%E6%8B%86%E9%99%A4%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%EF%BC%8CNBU%20%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%20AN14003%20%E4%B8%AD%E7%9A%84%E8%A7%84%E5%AE%9A%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A6%81%E4%BD%BF%E7%94%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%8A%A0%E8%BD%BD%20NBU%20%E6%98%A0%E5%83%8F%EF%BC%8C%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20PTC2%20%E5%92%8C%20PTC3%20%5BLPUART1%5D%EF%BC%9B%E8%AF%A5%E8%BF%9E%E6%8E%A5%E5%85%81%E8%AE%B8%20ROM%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20blhost%20%E5%8A%A0%E8%BD%BD%20KW45%20%E9%BB%98%E8%AE%A4%E6%8C%89%E9%94%AE%E5%92%8C%20NBU%20%E6%98%A0%E5%83%8F%E3%80%82%E5%BB%BA%E8%AE%AE%E9%80%89%E6%8B%A9%E5%B0%86BOOT_CFG%20%5BPTA4%5D%20%E8%B0%83%E8%87%B3%E9%80%BB%E8%BE%91%E9%AB%98%E7%94%B5%E5%B9%B3%E4%BB%A5%E4%BD%BF%E8%AE%BE%E5%A4%87%E8%BF%9B%E5%85%A5%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%90%8C%E6%97%B6%E4%B9%9F%E5%BB%BA%E8%AE%AE%E4%BA%92%E8%81%94%E7%BD%91%E6%9C%8D%E5%8A%A1%E6%8F%90%E4%BE%9B%E5%95%86%E4%BD%BF%E7%94%A8%E7%9A%84%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E5%AE%9E%E4%BE%8B%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E5%B0%86%E5%85%B6%E8%BF%9E%E6%8E%A5%E5%88%B0UART%E5%88%B0USB%E5%8F%98%E6%B5%81%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DKW45RM%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKW45%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FA%3E%E7%AC%AC%2016%20%E7%AB%A0%E8%A1%A8%2074%20%E5%92%8C%E3%80%8A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-MCU%2FThe-best-way-to-build-a-PCB-first-time-right-with-KW45%2Fm-p%2F1592481%2Fthread-id%2F14455%2Femcs_t%2FS2h8ZW1haWx8Ym9hcmRfc3Vic2NyaXB0aW9ufE1ETjZNTzY1SjBEOVFVfDE1OTI0ODF8U1VCU0NSSVBUSU9OU3xoSw%3Fattachment-id%3D165531%22%20target%3D%22_blank%22%3E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E5%BB%BA%E8%AE%AE%3C%2FA%3E%E3%80%8B%E5%B9%BB%E7%81%AF%E7%89%87%2052%20BOOTLOADER%20%E7%AB%A0%E8%8A%82%E4%B8%AD%E6%8F%8F%E8%BF%B0%E4%BA%86%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%8F%8F%E8%BF%B0%E4%B8%80%E4%B8%8B%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%E7%9A%84%E8%BF%87%E7%A8%8B%EF%BC%9FRESET%20%E6%97%B6%E4%BD%A0%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%8E%20BOOT_CFG%20%5BPTA4%5D%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E5%88%B0%20VDD%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%86%20UART0%20%E8%BF%9E%E6%8E%A5%E6%9B%B4%E6%94%B9%E4%B8%BA%20UART1%EF%BC%8C%E4%BB%A5%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%E5%B9%B6%E4%B8%8A%E4%BC%A0%20KW45%20%E9%BB%98%E8%AE%A4%E5%AF%86%E9%92%A5%E5%92%8C%20NBU%20%E6%98%A0%E5%83%8F%20%5BSDK%20v25.09%5D%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%B8%8A%E8%BF%B0%E6%96%B9%E6%B3%95%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20blhost%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%20SDK%20%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E4%BD%BF%E7%94%A8%20SDK%20%E7%A4%BA%E4%BE%8B%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%20%5B25.09%5D%EF%BC%8C%E4%BB%A5%E5%8C%B9%E9%85%8D%20NBU%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eblhost%20%E6%B2%A1%E6%9C%89%E6%A3%80%E6%B5%8B%E5%88%B0%E6%88%91%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9D%BF%E7%9A%84%20UART%20%E8%BD%AC%20USB%20%E5%8F%98%E6%B5%81%E5%99%A8%E3%80%82%E6%88%91%E5%9C%A8%20COM8%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E5%8F%98%E6%B5%81%E5%99%A8%EF%BC%8C%E4%BD%86%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%8E%20COM15%20%E5%8F%98%E6%B5%81%E5%99%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cnew01_0-1759940680248.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cnew01_0-1759940680248.png%22%20style%3D%22width%3A%20381px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359931i6FA2BD57DC74C80A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cnew01_0-1759940680248.png%22%20alt%3D%22cnew01_0-1759940680248.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecnew01_0-1759940680248.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E5%B8%AE%E6%88%91%E4%BB%AC%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E7%94%B5%E8%84%91%E8%AE%BE%E5%A4%87%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%A5%E5%85%B7%E4%B8%AD%E7%AB%AF%E5%8F%A3%20(COM%20%26amp%3B%20LPT)%20%E9%83%A8%E5%88%86%E4%B8%8B%E6%96%B9%E7%9A%84%E9%80%9A%E4%BF%A1%E7%AB%AF%E5%8F%A3%20%5BUART%5D%20%E6%98%AF%E5%90%A6%E8%A2%AB%E6%AD%A3%E7%A1%AE%E6%A3%80%E6%B5%8B%E4%B8%BA%E9%80%9A%E4%BF%A1%E7%AB%AF%E5%8F%A3%20%5BUART%5D%EF%BC%9F%E8%BF%99%E5%B0%86%E6%9C%89%E5%8A%A9%E4%BA%8E%E7%A1%AE%E8%AE%A4%20COM%20%E8%BF%9E%E6%8E%A5%E6%98%AF%E5%90%A6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%E3%80%82%E6%A0%B9%E6%8D%AE%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%91%BD%E4%BB%A4%E4%BC%BC%E4%B9%8E%E4%BD%BF%E7%94%A8%20COM15%EF%BC%8C%E8%80%8C%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%20COM7%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%9C%A8%E8%AE%BE%E5%A4%87%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%EF%BC%8C%E4%BD%A0%E5%BA%94%E8%AF%A5%E7%9C%8B%E5%88%B0%E8%BF%99%E6%A0%B7%E7%9A%84%E5%86%85%E5%AE%B9%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22luis_maravilla_1-1759518234464.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22luis_maravilla_1-1759518234464.png%22%20style%3D%22width%3A%20236px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359494iB12300C45D518ED9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22luis_maravilla_1-1759518234464.png%22%20alt%3D%22luis_maravilla_1-1759518234464.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eluis_maravilla_1-1759518234464.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorluis_maravilla_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E7%A1%AE%E8%AE%A4%E8%BF%9E%E6%8E%A5%E4%B8%BA%20COM7%EF%BC%8C%E8%AF%B7%E9%87%8D%E8%AF%95%20blhost%20%E5%91%BD%E4%BB%A4%20%5Bblhost%20-p%20COM7%20get-property%200x01%5D%EF%BC%8C%E4%BB%A5%E9%AA%8C%E8%AF%81%E8%BF%9E%E6%8E%A5%E5%93%8D%E5%BA%94%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%AD%A4%E5%91%BD%E4%BB%A4%E6%88%90%E5%8A%9F%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20COM7%20%E8%80%8C%E4%B8%8D%E6%98%AF%20COM15%20%E9%87%8D%E8%AF%95%20MCUXpresso%20%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E6%AD%A5%E9%AA%A4%E6%9D%A5%E6%9B%B4%E6%96%B0%20NBU%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E7%9A%84%E5%8F%91%E7%8E%B0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%3CSPAN%3EKW45B41Z83AFTBR%3CBR%20%2F%3E%3C%2FSPAN%3E%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20blhost%E3%80%82%3C%2FP%3E%3CP%3E%E6%AF%8F%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E6%97%B6%EF%BC%8C%E9%83%BD%E4%BC%9A%E5%BE%97%E5%88%B0%E4%BB%A5%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cnew01_2-1759425504764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cnew01_2-1759425504764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359342iFC07FA1385B631BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cnew01_2-1759425504764.png%22%20alt%3D%22cnew01_2-1759425504764.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecnew01_2-1759425504764.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPUART0%20%E5%BC%95%E8%84%9A%E7%9A%84%20USB%20%E8%BD%AC%20UART%20%E9%80%82%E9%85%8D%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%81%9A%E5%88%B0%E4%BB%A5%E4%B8%8B%E5%87%A0%E7%82%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cnew01_0-1759425255307.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cnew01_0-1759425255307.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359340iA62D671C41531DA3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cnew01_0-1759425255307.png%22%20alt%3D%22cnew01_0-1759425255307.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecnew01_0-1759425255307.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%99%84%E4%B8%8A%E9%94%99%E8%AF%AF%E5%8F%82%E8%80%83%E7%9A%84%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E3%80%82%E6%88%91%E7%9A%84%20USB%20%E8%BD%AC%20TTL%20%E4%B8%B2%E8%A1%8C%E6%8E%A5%E5%8F%A3%E5%BA%94%E8%BF%9E%E6%8E%A5%E5%88%B0%20COM15%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E4%BB%AC%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%20KW45%20%E5%A4%84%E4%BA%8E%E5%93%AA%E4%B8%AA%20OEM%20%E7%8A%B6%E6%80%81%E5%90%97%EF%BC%9F%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20blhost%20%E5%B7%A5%E5%85%B7%E5%91%BD%E4%BB%A4%22blhost%20-p%20COMx%20get-property%200x01%22%20%EF%BC%8C%E5%B9%B6%E4%B8%8E%E6%88%91%E4%BB%AC%E5%88%86%E4%BA%AB%E5%93%8D%E5%BA%94%EF%BC%9F%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%20KW45%20%E7%9A%84%E5%AE%8C%E6%95%B4%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FKW45.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKW45B%EF%BC%88%E6%97%A0%E7%BA%BF%E7%94%B5%EF%BC%89%E5%92%8C%20KW45Z%EF%BC%88MCU%EF%BC%89%E6%95%B0%E6%8D%AE%E8%A1%A8%3C%2FA%3E%E4%B8%AD%E7%9A%84%E8%A1%A8%201%20%E6%9F%A5%E7%9C%8B%E9%83%A8%E4%BB%B6%E5%8F%B7%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8D%B3%E4%BD%BF%E6%98%AF%20LED%20Blinky%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E7%A8%8B%E5%BA%8F%E4%B9%9F%E4%BC%9A%E5%8D%A1%E5%9C%A8%200x14816fdc%20%E5%A4%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E7%A1%AE%E8%AE%A4%E6%82%A8%E6%98%AF%E5%90%A6%E8%83%BD%E5%A4%9F%E5%9C%A8%E6%9D%BF%E4%B8%8A%E5%88%B7%E6%9C%BA%E5%B9%B6%E8%BF%90%E8%A1%8C%E4%BB%BB%E4%BD%95%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%B8%8D%E5%8C%85%E6%8B%AC%E6%97%A0%E7%BA%BF%E6%88%96%E4%BD%8E%E5%8A%9F%E8%80%97%E8%93%9D%E7%89%99%E7%A4%BA%E4%BE%8B%EF%BC%89%EF%BC%9F%EF%BC%8C%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%EF%BC%8C%E6%88%91%E6%83%B3%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E5%8D%B3%E4%BD%BF%E8%BF%90%E8%A1%8C%E4%B8%8D%E9%9C%80%E8%A6%81%20NBU%20%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%9D%BF%E6%98%AF%E5%90%A6%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%B5%8B%E8%AF%95%20SDK%20%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BB%A5%E9%AA%8C%E8%AF%81%E5%9F%BA%E6%9C%AC%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%AF%B7%E5%B0%86%E6%9D%BF%E7%9A%84%E4%B8%B2%E8%A1%8C%E8%BF%9E%E6%8E%A5%E4%B8%8E%20KW45B41Z-EVK%20%E5%8E%9F%E7%90%86%E5%9B%BE%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%EF%BC%8C%E7%A1%AE%E4%BF%9D%E5%85%B6%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E6%9F%A5%E9%98%85%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DKW45B41Z-EVK_SCH%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKW45B41Z%20%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%E6%9D%BF%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELuis%3A%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%20SPSDK%EF%BC%8C%E5%B9%B6%E6%89%BE%E5%88%B0%E4%BA%86%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E5%B7%A5%E5%85%B7%E3%80%82%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%88%91%E6%B2%A1%E6%9C%89%20USB%20%E7%9A%84%E6%9D%BF%E8%BD%BD%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%88%91%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20USB%20%E8%BD%AC%20UART%20%E5%8F%98%E6%B5%81%E5%99%A8%E3%80%82%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%88%91%E7%9A%84%20USB%20%E8%BD%AC%20TTL%20%E5%8F%98%E6%B5%81%E5%99%A8%E8%AE%A9%E8%BD%AF%E4%BB%B6%E6%89%BE%E4%B8%8D%E5%88%B0%E6%88%91%E7%9A%84%E6%9D%BF%EF%BC%88%E5%9C%A8%20USB%20%E7%AB%AF%E5%8F%A3%E4%B8%8A%EF%BC%89%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cnew01_0-1758913567835.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cnew01_0-1758913567835.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F358771iDF1EE89B53E04B34%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cnew01_0-1758913567835.png%22%20alt%3D%22cnew01_0-1758913567835.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecnew01_0-1758913567835.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%EF%BC%8C%E6%88%91%E5%9C%A8%E7%BB%88%E7%AB%AF%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%20nxpdebugmbox%20cmd%20-f%20kw45b41z8%20ispmode%20-m%201%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%20ISP%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E7%BB%88%E7%AB%AF%E6%98%BE%E7%A4%BA%E8%AE%BE%E7%BD%AE%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%9C%AC%E8%AF%B4%E6%98%8E%E6%B6%89%E5%8F%8A%20%22%20%3CSTRONG%3EmcuxPresso%20%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%20%22%3C%2FSTRONG%3E%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%20%22%20mcuxPresso%20%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%20%3CSTRONG%3E25.06%3C%2FSTRONG%3E%20%22%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E4%B8%8B%E8%BD%BD%E8%AF%A5%E5%B7%A5%E5%85%B7%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%23%3A~%3Atext%3DWireless%2520Connectivity-%2CDownloads%2C-Quick%2520reference%2520to%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMCUXpresso%20%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E4%B8%8B%E8%BD%BD%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%AF%A5%E5%B7%A5%E5%85%B7%3C%2FA%3E%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%B7%A5%E4%BD%9C%E7%A9%BA%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorluis_maravilla_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22luis_maravilla_1-1758912500801.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22luis_maravilla_1-1758912500801.png%22%20style%3D%22width%3A%20322px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F358769i40D56ACB788290AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22luis_maravilla_1-1758912500801.png%22%20alt%3D%22luis_maravilla_1-1758912500801.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eluis_maravilla_1-1758912500801.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%20MCUXpresso%20%E4%B8%AD%E6%89%BE%E5%88%B0%E5%8F%91%E9%80%81%E7%9A%84%E6%8C%87%E5%8D%97%E4%B8%AD%E6%8C%87%E5%AE%9A%E7%9A%84%E5%B7%A5%E5%85%B7%26gt%3B%20%E5%88%B6%E9%80%A0%E5%B7%A5%E5%85%B7%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E6%9B%B4%E5%A4%9A%E6%9C%80%E6%96%B0%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%85%B1%E4%BA%AB%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%88%96%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%A0%94%E7%A9%B6%E4%BB%80%E4%B9%88%EF%BC%8C%E6%AD%A3%E5%A6%82%E4%BD%A0%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E4%BD%A0%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20AN14003%20%E7%83%A7%E6%AF%81%E7%86%94%E4%B8%9D%E7%9A%84%E9%BB%98%E8%AE%A4%E5%AF%86%E9%92%A5%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%90%A6%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E7%AC%AC%203.3%20%E8%8A%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-kw45b41z-evaluation-kit%3AGS-KW45B41ZEVK%3Fsection%3Dbuild-run%23%3A~%3Atext%3D3.3-%2CUpdating%2520NBU%2520for%2520Wireless%2520Examples%2C-Alert%2520code%253A%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%9B%B4%E6%96%B0%E6%97%A0%E7%BA%BF%E7%A4%BA%E4%BE%8B%E7%9A%84%20NBU%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E6%9B%B4%E6%96%B0%20NBU%20%E9%95%9C%E5%83%8F%EF%BC%8C%E5%9B%A0%3C%2FA%3E%E4%B8%BA%20SDK%20%E4%B8%AD%E7%9A%84%20sb3%20%E6%96%87%E4%BB%B6%E9%80%82%E7%94%A8%E4%BA%8E%20KW45%20%E6%9D%BF%E4%B8%AD%E7%83%A7%E5%BD%95%E7%9A%84%E9%BB%98%E8%AE%A4%E5%AF%86%E9%92%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E4%BB%AC%E7%A1%AE%E8%AE%A4%E7%86%94%E4%B8%9D%E7%83%A7%E6%AF%81%E8%BF%87%E7%A8%8B%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E8%83%BD%E5%90%A6%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%85%B1%E4%BA%AB%E6%98%BE%E7%A4%BA%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E7%A1%AE%E8%AE%A4%E6%98%AF%E5%90%A6%E8%83%BD%E9%A1%BA%E5%88%A9%E8%BF%9B%E5%85%A5%20ISP%20%E6%A8%A1%E5%BC%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%B0%9D%E8%AF%95%E8%B0%83%E8%AF%95%E6%97%B6%E6%88%91%E8%BF%98%E4%BC%9A%E5%8E%BB%E5%90%AF%E5%8A%A8%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E9%82%A3%E4%B8%AA%E5%9C%B0%E5%9D%80%E3%80%82%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E6%88%91%E5%8F%AF%E4%BB%A5%E8%B0%83%E6%9F%A5%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167015%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167015%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EPLATFORM_OtaGetOtaInternalPartitionConfig%26nbsp%3B%3C%2FSTRONG%3E%20returns%20internal%20partition%20configuration%20structure%2C%20what%20you%20could%20try%20is%20make%20the%20initialization%20manually%2C%20to%20ensure%20the%20internal%20flash%20is%20selected%20and%20the%20values%20start%20at%200.%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20if%20that%20worked%20for%20you.%3C%2FP%3E%0A%3CPRE%20class%3D%22language-plaintext%22%3E%3CCODE%3EOtaPartition_t%20Test_ota_partition%20%3D%20%0A%7B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*start_offset*%2F%200%2C%5C%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*size*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B0%2C%5C%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*sector_size*%2F%26nbsp%3B%26nbsp%3B0%2C%5C%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*page_size*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B0%2C%5C%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*internal_flash*%2F%20true%2C%5C%0A%20%20%20%20%2F*spi_baudrate*%2F%200%2C%5C%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3Eloader_info.partition_desc%20%3D%20%26amp%3BTest_ota_partition%3B%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20evk%20sb3%20%E6%8C%89%E7%85%A7%20an14003%20%E7%AC%AC%205%20%E8%8A%82%EF%BC%88%E7%9C%81%E7%95%A5%E7%AC%AC%203%20%E8%8A%82%EF%BC%89%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E6%89%80%E5%81%9A%E7%9A%84%E4%B8%80%E4%B8%AA%E4%BF%AE%E6%94%B9%E6%98%AF%E8%AE%BE%E7%BD%AE%3CBR%20%2F%3E%3CSPAN%3E%20loader_info.partition_desc%20%3D%20platform_otageTotaInternalPartitionConfig%20()%EF%BC%9B%E5%90%88%E5%B9%B6%E7%94%9F%E6%88%90%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%92%8C%3CBR%20%2F%3E%3C%2FSPAN%3E%20SB3%20%E5%90%8E%E6%88%91%E8%BF%98%E4%BC%9A%E9%81%87%E5%88%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%3CEM%3Etest_ota_partition%3C%2FEM%3E%E5%87%BD%E6%95%B0%E4%BD%BF%E7%94%A8%3CSTRONG%3Efwk_platform_ota.h%3C%2FSTRONG%3E%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%3CSTRONG%3EOtaPartition_t%3C%2FSTRONG%3E%E7%BB%93%E6%9E%84%E3%80%82%E7%94%A8%E4%BA%8E%E7%AE%A1%E7%90%86%20AN14003%20%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E5%85%B6%E4%BB%96%E6%AD%A5%E9%AA%A4%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%20OTA%20%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E7%BB%93%E6%9E%84%E6%8F%8F%E8%BF%B0%E4%BA%86%E7%A9%BA%E4%B8%AD%E4%B8%8B%E8%BD%BD%EF%BC%88OTA%EF%BC%89%E6%9B%B4%E6%96%B0%E5%88%86%E5%8C%BA%E7%9A%84%E7%89%B9%E5%BE%81%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%81%8F%E7%A7%BB%E9%87%8F%E3%80%81%E5%A4%A7%E5%B0%8F%E3%80%81%E6%89%87%E5%8C%BA%E5%92%8C%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%E4%BB%A5%E5%8F%8A%E9%97%AA%E5%AD%98%E6%98%AF%E5%86%85%E9%83%A8%E8%BF%98%E6%98%AF%E5%A4%96%E9%83%A8%E7%AD%89%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20AN14003%20%E6%B3%A8%E9%87%8A%E4%B8%AD%E6%89%80%E8%BF%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20test_OTA_Partition%EF%BC%8C%E5%88%99%E8%A1%A8%E7%A4%BA%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%E5%8F%82%E6%95%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%EF%BC%8C%E5%88%99%E4%B8%BA%20test_OTA_Partition%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E9%9C%80%E8%A6%81%E6%AF%8F%E4%BD%8D%E5%AE%A2%E6%88%B7%E8%87%AA%E8%A1%8C%E5%AE%9E%E6%96%BD%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%E5%8C%85%E5%90%AB%E5%AE%9A%E4%B9%89%E7%9A%84%E7%BB%93%E6%9E%84%20%5B%E6%91%98%E8%87%AA%3CSTRONG%3E%20fwk_platform_ota.h%3C%2FSTRONG%3E%5D%20%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-cpp%22%3E%3CCODE%20translate%3D%22no%22%3Etypedef%20struct%0A%7B%0A%20%20%20%20uint32_t%20start_offset%3B%20%2F*!%26lt%3B%20Offset%20of%20firmware%20update%20partition%20in%20flash%20device.%20The%20physical%20address%20is%20translated%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20by%20flash%20driver%20*%2F%0A%20%20%20%20uint32_t%20size%3B%20%20%20%20%20%20%20%20%20%2F*!%20Size%20of%20firmware%20update%20storage%20expressed%20in%20bytes%20*%2F%0A%20%20%20%20uint32_t%20sector_size%3B%20%20%2F*!%20Sector%20size%20of%20flash%20used%20for%20OTA%2C%20usually%204kB%20for%20external%20flash%20but%20varies%20for%20internal%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20flash%20*%2F%0A%20%20%20%20uint32_t%20page_size%3B%20%20%20%20%2F*!%20Page%20size%20of%20flash%20device%20%3A%20minimal%20program%20size*%2F%0A%20%20%20%20bool%20%20%20%20%20internal_flash%3B%20%2F*!%20true%20if%20internal%20flash%2C%20false%20for%20SPI%20NOR%20Flash%20*%2F%0A%20%20%20%20uint32_t%20spi_baudrate%3B%20%20%20%2F*!%20SPI%20baudrate%20concerns%20only%20external%20flash%20if%20flash%20config%20is%20not%20used%20KW45%20case%20*%2F%0A%7D%20OtaPartition_t%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELuis%EF%BC%9A%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%AE%9E%E7%8E%B0%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%8C%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%AF%86%E9%92%A5%E6%9D%A5%E9%AA%8C%E8%AF%81%E8%BF%99%E4%B8%AA%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%E5%9C%A8%20an14003%20%E4%B8%AD%EF%BC%8C%3CSPAN%3E%E7%AC%AC%2013%20%E9%A1%B5%E4%B8%8A%E7%9A%84%20Test_ota_partition%20%E5%9C%A8%20OTAP%20%E7%A4%BA%E4%BE%8B%E6%88%96%E6%8F%90%E4%BE%9B%E7%9A%84%E5%85%B6%E4%BB%96%E4%BB%A3%E7%A0%81%E4%B8%AD%E9%83%BD%E6%B2%A1%E6%9C%89%E5%AE%9A%E4%B9%89%E3%80%82%E8%BF%99%E4%B8%AA%E5%8F%98%E9%87%8F%E5%BA%94%E8%AF%A5%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E7%A1%AE%E8%AE%A4%E6%82%A8%E7%9A%84%E6%9C%80%E7%BB%88%E7%9B%AE%E6%A0%87%E6%98%AF%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20KW45%20%E7%9A%84%E5%AE%9A%E5%88%B6%20PCB%EF%BC%8C%E4%B8%8E%E4%BD%BF%E7%94%A8%20SDK%20%E7%A4%BA%E4%BE%8B%E7%9A%84%20KW45B41Z-EVK%20%E7%9B%B8%E5%90%8C%EF%BC%8C%E8%BF%98%E6%98%AF%E7%94%A8%E4%BA%8E%E5%AE%9A%E5%88%B6%E5%BA%94%E7%94%A8%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%BC%9A%E5%B9%B2%E6%89%B0%E8%8A%AF%E7%89%87%E7%83%A7%E6%AF%81%E6%89%80%E9%9C%80%E7%9A%84%E7%86%94%E4%B8%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E5%B0%86%20NBU%20%E6%98%A0%E5%83%8F%E6%9B%B4%E6%96%B0%E5%88%B0%20KW45%20%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%90%91%20KW45%20%E7%86%94%E4%B8%9D%E5%86%99%E5%85%A5%E4%B8%A4%E7%A7%8D%E7%B1%BB%E5%9E%8B%E7%9A%84%E5%AF%86%E9%92%A5%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E4%B8%BA%20KW45B41Z-EVK%20%E6%9D%BF%E6%8F%90%E4%BE%9B%20rotKTH%20%E5%92%8C%20SB3KDK%EF%BC%9B%E4%BD%86%E5%9C%A8%E5%87%BA%E5%8E%82%E8%8A%AF%E7%89%87%E4%B8%AD%EF%BC%8C%E7%86%94%E4%B8%9D%E4%B8%AD%E7%9A%84%E5%AF%86%E9%92%A5%E4%B8%BA%E7%A9%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AF%B9%E4%BA%8E%E5%B7%A5%E5%8E%82%E8%8A%AF%E7%89%87%EF%BC%8C%E5%AE%A2%E6%88%B7%E9%9C%80%E8%A6%81%E6%8C%89%E7%85%A7%20%5B%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14003%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN14003%20%E5%9C%A8%E6%89%B9%E9%87%8F%E7%94%9F%E4%BA%A7%E6%9C%9F%E9%97%B4%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8C%E7%BA%BF%E8%B0%83%E8%AF%95%E4%B8%BA%E5%BA%94%E7%94%A8%E5%92%8C%E6%97%A0%E7%BA%BF%E7%94%B5%E5%9B%BA%E4%BB%B6%E7%BC%96%E7%A8%8B%20KW45%20%E9%97%AA%E5%AD%98%5D%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E7%83%A7%E6%AF%81%E4%B8%8E%E6%9C%80%E7%BB%88%E7%9B%AE%E6%A0%87%E7%9B%B8%E5%85%B3%E7%9A%84%E7%86%94%E4%B8%9D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B8%8E%20KW45B41Z-EVK%20%E7%9B%B8%E5%90%8C%E7%9A%84%E6%9D%BF%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%20KW45B41Z-EVK%20%E6%9D%BF%E4%B8%AD%E7%9A%84%E7%9B%B8%E5%90%8C%E5%AF%86%E9%92%A5%E5%80%BC%20%5B%E5%9C%A8%20AN14003%20%E7%AC%AC%205.2.1%20%E7%AB%A0%E5%9B%BE%209%20%E4%B8%AD%E6%8F%8F%E8%BF%B0%5D%EF%BC%9B%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E5%B0%86%E8%87%AA%E5%B7%B1%E7%9A%84%E6%9D%BF%E7%94%A8%E4%BA%8E%E5%85%B6%E4%BB%96%E7%BB%88%E7%AB%AF%E4%BA%A7%E5%93%81%E6%88%96%E8%87%AA%E5%AE%9A%E4%B9%89%E7%BB%88%E7%AB%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9B%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E8%87%AA%E5%B7%B1%E5%88%9B%E5%BB%BA%E5%AF%86%E9%92%A5%E5%B9%B6%E4%BD%BF%E7%94%A8%20.xip%20%E7%94%9F%E6%88%90%20sb3%20%E6%96%87%E4%BB%B6%E7%94%B3%E8%AF%B7%E4%B8%80%E5%BC%A0%E4%B8%93%E7%94%A8%E4%BA%8E%E6%82%A8%E7%9A%84%E6%9C%80%E7%BB%88%E4%BA%A7%E5%93%81%E7%9A%84%E6%96%B0%20NBU%20%E5%9B%BE%E7%89%87%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E6%9B%B4%E6%96%B0%20NBU%EF%BC%9B%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B8%8E%20KW45B41Z-EVK%20%E7%9B%B8%E5%90%8C%E7%9A%84%E6%9D%BF%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%B8%8E%20SDK%20%E6%96%87%E4%BB%B6%E5%A4%B9%E7%9B%B8%E5%90%8C%E7%9A%84%20sb3%20%E6%96%87%E4%BB%B6%E6%9D%A5%E6%9B%B4%E6%96%B0%20NBU%EF%BC%9B%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E5%B0%86%E6%9D%BF%E7%94%A8%E4%BA%8E%E5%85%B6%E4%BB%96%E7%BB%88%E7%AB%AF%E4%BA%A7%E5%93%81%E6%88%96%E8%87%AA%E5%AE%9A%E4%B9%89%E7%BB%88%E7%AB%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%88%99%E5%BA%94%E6%8C%89%E7%85%A7%20AN14003%20%E7%AC%AC%204%20%E7%AB%A0%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E8%AF%B4%E6%98%8E%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%20sb3%20%E6%96%87%E4%BB%B6%E6%9D%A5%E4%B8%8A%E4%BC%A0%20NBU%20%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%80%BC%E5%BE%97%E4%B8%80%E6%8F%90%E7%9A%84%E6%98%AF%EF%BC%8C%E6%9C%AC%E6%96%87%E6%A1%A3%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E7%83%A7%E6%AF%81%E7%86%94%E4%B8%9D%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E4%B8%8D%E5%8F%AF%E9%80%86%E7%9A%84%E3%80%82%E5%9C%A8%20KW45%20%E4%B8%8A%E7%BC%96%E7%A8%8B%E4%B8%BA%E7%86%94%E4%B8%9D%E7%9A%84%E6%8C%89%E9%94%AE%E6%97%A0%E6%B3%95%E5%86%8D%E6%9B%B4%E6%94%B9%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BB%BA%E8%AE%AE%E8%B0%A8%E6%85%8E%E4%BF%AE%E6%94%B9%E7%86%94%E4%B8%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%86%94%E4%B8%9D%E5%B0%9A%E6%9C%AA%E7%83%A7%E6%AF%81%EF%BC%8CKW45%E6%98%AF%E7%94%A8%E7%BB%87%E7%89%A9%E5%88%B6%E6%88%90%E7%9A%84%E3%80%82%E6%9B%B4%E6%96%B0%E8%8A%AF%E7%89%87%E4%B8%8A%E7%9A%84%20NBU%20%E4%BB%A5%E5%89%8D%E4%BB%8E%E6%9C%AA%E5%81%9A%E8%BF%87%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E5%86%85%E5%AD%98%E5%9C%B0%E5%9D%80%E6%8C%87%E7%9A%84%E6%98%AF%20ROM-%E5%90%AF%E5%8A%A8%20%5B%E8%A1%A8%2016%20KW45%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%5D%EF%BC%8C%E5%9C%A8%20KW45%20%E4%B8%8A%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%90%AF%E5%8A%A8%20ROM%20%E6%89%8D%E8%83%BD%E8%AE%BF%E9%97%AE%20NBU%20%E9%97%AA%E5%AD%98%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20ROM%20%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20AN14003%20%E5%9B%BE%202%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BD%93%E4%BD%A0%E5%9C%A8%E5%AE%9A%E5%88%B6%20PCB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20Fabric%20%E7%9A%84%20KW45%20%E8%8A%AF%E7%89%87%E6%97%B6%EF%BC%9B%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E4%BB%AC%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E4%BD%A0%E7%9A%84%20Fabric%20KW45%20%E8%8A%AF%E7%89%87%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E6%8C%89%E7%85%A7%20AN14003%20%E4%B8%AD%E6%89%80%E8%BF%B0%E7%9A%84%E8%BF%87%E7%A8%8B%E7%86%94%E4%B8%9D%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%80%8C%E4%B8%94%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%BB%8F%E7%83%A7%E6%AF%81%E4%BA%86%E7%86%94%E4%B8%9D%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E4%BA%86%E7%AC%AC%205.2.1%20%E7%AB%A0%20%5BAN14003%5D%20%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E9%BB%98%E8%AE%A4%20KW45B41Z-EVK%20%E5%AF%86%E9%92%A5%20%5BSBKDK%20%E5%92%8C%20rotKTH%5D%EF%BC%9F%E6%88%96%E8%80%85%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E7%94%9F%E6%88%90%E7%9A%84%E6%9D%BF%E5%AF%86%E9%92%A5%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%E9%9C%80%E8%A6%81%E7%A1%AE%E8%AE%A4%E7%9A%84%E6%98%AF%EF%BC%8C%E6%82%A8%E4%BB%A5%E5%89%8D%E5%9C%A8%E8%8A%AF%E7%89%87%E4%B8%8A%E6%9B%B4%E6%96%B0%E8%BF%87%20NBU%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20First%20Time%20Programming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%A6%81%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%EF%BC%8CLPUART0%20TX%20%E5%92%8C%20RX%20%E5%BC%95%E8%84%9A%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E4%B8%AA%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E4%B8%8A%E9%80%9A%E8%BF%87%E6%8E%A5%E5%A4%B4%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
