KW41Z
KW41Z
1,966 次查看
divyajyothi
Hi Community,
We are planned to use KW41Z and K32W0 wireless BLE and Zigbee chipset in one of our project.
Please help me to clarify the below queries regarding the 2 chipsets.
  • Whether both chip sets supports BLE long range Coded Phy ?
  • Its supports OTA firmware updates ?
  • Can it is possible to increase BLE O/P power upto +20dBm by using external PA/LNA ?If it so, please suggest the external PA for this application.
  • As we are using only one Antenna for both BLE and Zigbee, please suggest the PA/LNA part for 1 RF output channel
Thanks & regards,
Divya
1,819 次查看
stephanie_m
Sorry for the inconvenience this might cause you, but as the K32W product has not been released yet I do not have any information available to share with you, nonetheless, could you please contact one distributor available in the Distributor Network|NXP   or one of the NXP sales representatives to help you with the request?
Regarding the KW41, by any chance, have you checked the KW41Z/31Z/21Z Power Amplifier Reference Design|NXP ?
Does this works for you?
Estephania
