KW38 debug via PEmicro
2,485 次查看
LISI1
HI, At present, when developing KW38, we have encountered problems of burning and debugging. Errors are as follows
ide:MCUXpresso IDE v11.9.1_2170
Looking forward to your reply, thank you.
2,383 次查看
LISI1
Thank you, the issue has been resolved, will be closed
2,428 次查看
Itzel_UV
I will be helping you in this case,
I notice that you have 2 questions with the topic involving the KW38, by any chance are they related? I that case, the communication will be at this same thread for practicality.
Could you confirmed if you're using a same custom board?
kw38 debug failure via external jlink - NXP Community
Itzel
2,440 次查看
LISI1
Can you help me with that? Thank you
