K32W Multilink
K32W Multilink
5,145件の閲覧回数
danieltseng
Contributor V
Because K32W is a new chip, it has the following problems:
1. Does the SWD interface on the K32W main board support Multilink (debug tool) download  as usual?
2. If not support  Multilink , what debug tool can be supported?
  • KW
9 返答(返信)
4,901件の閲覧回数
danieltseng
Contributor V
Dear Mario,
Thank you for your response, currently resolved.
4,901件の閲覧回数
danieltseng
Contributor V
Hi Mario,
It's been a week since this question, is there any test result?
4,901件の閲覧回数
mario_castaneda
Hi Daniel,
Please accept my apologies for the late response.
Unfortunately, K32W is supporting the following probes:
Link2 debug probe with ARM’s CMSIS-DAP and SEGGER J-Link protocol options.
Boards user manual: https://www.nxp.com/docs/en/user-guide/UM11393%20.pdf
NXP open SDA J& link2:
   LPC-Link2 | NXP
  OpenSDA Serial and Debug Adapter | NXP
Sorry for any inconvenience that this may cause you.
Mario
4,901件の閲覧回数
mario_castaneda
Hi Daniel,
I hope you are doing great.
Sorry for my late response, We are still working on it. We are facing some delays for all of this COVID Novel.
I will get back to you as soon as possible.
Mario
4,901件の閲覧回数
danieltseng
Contributor V
Hi Mario,
Multilink is urgent currently , can you help me check this function first?
4,901件の閲覧回数
danieltseng
Contributor V
K32W multilink download
This is the result of my test, for your reference.There will be an error message。
In addition, I used Multilink to test that KW41 can be loaded normally, which means that my Multilink can work without damage.
4,901件の閲覧回数
danieltseng
Contributor V
In other words,
SWD interface on the Carrier Main Board support via Multilink  to download image to "LPC4322" or "K32W module chip"  ?
4,901件の閲覧回数
mario_castaneda
Hi Daniel,
I am checking the Multilink support. I will get back to you as soon as possible.
Mario
4,901件の閲覧回数
mario_castaneda
Hi Daniel,
The mainboard provides an LPC4322 with CMSIS DAP firmware. you could use this tool for debugging purposes. Also, you can use an external LPC LINK 2 for debugging purposes.
Mario
