JN5169 eval kits
JN5169 eval kits
swilson2
What is actually required to get started with JN5169 development? Do I need the full JN516x-EK004 kit (which is prohibitively expensive in Canada) or can I just start with the JN5169XK020 expansion kit (and perhaps the OM15020 USB module)?
mario_castaneda
Hi Sean,
You can star with the JN5169XK020 expansion kit, but I recommended to you to check the examples that you want to take a reference and look if with this kit you can prove an Application note.
Mario
