JN5169 Radio
JN5169 Radio
2,611 次查看
hongpengxie
Hello, I am using the JN-5169 module, I see above the document on the antenna settings, bAHI_PhyRadioSetPower ();
When I want to increase the communication distance in JN-1189 can not find the corresponding function. Is there any other way to increase the communication distance? (Equipment directly to the coordination side)
3 回复数
2,359 次查看
mario_castaneda
Please take a look to the next community post.
https://community.nxp.com/message/923715?commentID=923715#comment-923715
Hope it helps.
Mario
2,359 次查看
hongpengxie
I used the JN5169-001-M00-2 and did not use the high power module. I found from the JN5169-001-M0x-2 page on the second page: TX power 8.5 dBm / 10 dBm. Now i wanna know that this i have no way to change the TX power.
thanks
2,359 次查看
377086561
Hello, may you help me tell me, how did you do it? I am using JN-AN-1184.
