JN5168-001-M00Z Eagle Library
1,727件の閲覧回数
tcoin
I have purchased a JN5168-001-M00Z module, and a would like to make a breakout board (breadboard friendly) in order to try this module.
I would like to know if you have the associated Eagle library (symbol and footprint) for this module.
Also, I would like to know if it is possible to use the LPC Link2 JTAG prog to debug it. If not, is there a cheap debug prog ? (I'm a hobbyist)
Thanks by advance
Thomas
ラベル(2)
1,647件の閲覧回数
mario_castaneda
Hi Tomas,
Please look at the Datasheet https://www.nxp.com/docs/en/data-sheet/JN5168-001-MXX.pdf
Figure 5: Module PCB footprint
You could find the footprint that you are looking for.
Unfortunately, the LPC Link2 JTAG can not debug the JN5169 because it is a RISC 32 bits MCU, the LPC has not any information about the registers. I could recommend using the terminal to debug your application.
Sorry for the inconvenience that this may cause you.
Mario
