JN-AN-1171: Building error
sebastian_moral
I need some help to build the base application example from the AN-1171.
After installing the IDE, following the instructions of the document UG-3098 (installation of ide, sdk and plugins), I proceed to import the reference demo project from the AN folder.
After correct the include directive from the project options (see image) and select a build configuration, I attach the console output in a text file.
Any help over here will be apreciated.
Thanks!
Labels (2)
mario_castaneda
Hi Sebastian,
Could you please look at the Beyond Studio Common Errors  ?
What is the path location that you save the AN?
Mario
