Is JN5169 design with TOF
3,805件の閲覧回数
yuchenglin
Hello,I use JN5168 made an application of tof,now I want to use JN5169,is JN5169 design with TOF?
タグ(1)
6 返答(返信)
3,564件の閲覧回数
mario_castaneda
Hi Yucheng Lin,
Unfortunately, the JN5169 doesn't provide a TOF module.
Reference to TIme of Flight in JN5169 DS has been removed.
Mario
3,564件の閲覧回数
yuchenglin
hi Mario
   if the jn5169  doesn't provide a TOF module,is there any chip can repace jn5168?
   our chip supplier said that jn5168 has been stop production
3,564件の閲覧回数
mario_castaneda
Hi Yucheng Lin,
We do not recommend this module, has a limited support and the measure, that you will get, won't be correct.
Mario
3,564件の閲覧回数
yuchenglin
Hi Mario
   If I use JN5168 as the TOF master,and use JN5169 as the TOF slave,is that correct?
3,564件の閲覧回数
mario_castaneda
Hi Yucheng Lin,
Unfortunately, we do not recommend using this module
Mario
3,564件の閲覧回数
yuchenglin
Hi Mario Ignacio Castaneda Lopez
   but why I use the same progame with JN5168,it look like can work?
   I use the TOF function in JN5169,the distance calculate by tof look right?
